LS1 into a Vauxhall Astra Coupe
Old 11-07-2006 | 01:44 PM
  #201
Pete 1's Avatar
Originally Posted by qwikz28
i wish you were stateside so we can see this thing run around our streets
When it`s up and running, I`ll vid it for ya, and post it on here
Old 11-11-2006 | 11:07 AM
  #202
Pete 1's Avatar
Repositioned wishbone front tie rod, connected the steering rack, made the drop links for the ARB, and made a template for the new ARB ..........
Mounted the radiator ...............
And made the new link, and fitted the steering column .......
All in all, not a bad days work
Old 11-11-2006 | 04:45 PM
  #203
Schitzo's Avatar
wow Pete...you are on a roll......soon you will be whippin tail and takin names. all the best
Old 11-12-2006 | 03:03 AM
  #204
Pete 1's Avatar
Thanks bud
Gonna start on the zorst this week, and hopefully the rollcage.
Old 11-16-2006 | 03:41 PM
  #205
Pete 1's Avatar
Exhaust is underway ..........................
And so is the bulkhead ............................
Old 11-16-2006 | 04:49 PM
  #206
stevieturbo's Avatar
Nice welding....mines nearly as good !!!!! ( NOT )
I see you are opting for a lightweight bulkhead
Old 11-17-2006 | 01:10 AM
  #207
Pete 1's Avatar
lol yes mate
It will eventually be made from 18g Zintec
Old 11-18-2006 | 07:16 AM
  #208
chuntington101's Avatar
will the car need to go through SVA pete????
Chris.
Old 11-18-2006 | 07:41 AM
  #209
I would say, that if you follow the letter of the law, it should. But then, so should mine, and thousands of other vehicles in the UK
Drastic changes could be coming into force in the UK, which **** over a lot of cars. Including restored classics, as many have been restored from non-original parts. Enough of which, could render the car needing SVA'd
These proposals were doing the rounds a year or so ago in the magazines, warning readers to write to the DLVA basically telling them to wise up.
The NSRA is also appealing to them, as many of their "radically" altered vehicles could also end up requiring an SVA, and for many older vehicles, including restored classics, apparently this would be nigh on impossible for them to actually pass.
At best, they could end up with a Q plate. At worst,, they would simply be rendered illegal to use on the road.
Look at the thousands of drag orientated machines that exist, that bare litte-no resemblance to their original car.
Old 11-18-2006 | 10:54 AM
  #210
Pete 1's Avatar
I will be declaring everything to the DVLA, if they decide that it needs an SVA, it`ll be trailored to the Gillingham test centre and from there to the MOT station
As everything is GM, I`m hoping it wont be a Q plate, as I`ve already bought this .......
Old 11-18-2006 | 12:44 PM
  #211
http://img239.imageshack.us/my.php?i...arycopy4xx.gif
Everything is not Vauxhall Astra.
You get points totted up for each of these things you retain.
http://www.direct.gov.uk/Motoring/Bu...199&chk=iVQaD9
http://www.nsra.org.uk/forum/topic.asp?TOPIC_ID=16167
http://homepage.ntlworld.com/keithh205/dvla.htm
http://bbs.22b.com/cgi-bin/ultimateb...573;p=1#000000
I can understand you wanting to do everything by the book....and its probably right that you do.
But thats an extremely fucked up book they work from, and they keep changing the rules, mostly in a move to extort more money from us.
Old 11-18-2006 | 01:11 PM
  #212
Pete 1's Avatar
Thanks Steve, I think I`ll just tell `em "it`s had a new engine, gearbox and rear axle", might get away with it
Old 11-19-2006 | 05:34 AM
  #213
Chris5.7ltr's Avatar
Looking good there Pete, Me loving Hot Rods I also love something different and this project is forever in my mind.
Keep the updates coming, they never get boring!
Old 11-20-2006 | 01:23 PM
  #214
E36LUVA's Avatar
Hey Pete 1, newbe here. I've been roaming this site for a while and I finally decided to join. Brilliant work dude. What IRS setup are using. I'm just wondering if it'll hold up to the LS1 torque. Show us some pics of your other shop projects.
Old 11-20-2006 | 01:35 PM
  #215
Its complete running gear from a GTO !!!!!!
Old 11-20-2006 | 01:47 PM
  #216
E36LUVA's Avatar
Hey stevieturbo, you have a build up of your Granada/LS1/T56 anywhere???
Old 11-20-2006 | 02:18 PM
  #217
Pete 1's Avatar
Yeah, Stevie`s right, apart from Vaux Omega rear axle, but the drive shafts are 5mm bigger in dia than the GTO`s and I`m running an LSD from a Vauxhall Monza.
Old 11-20-2006 | 02:20 PM
  #218
Is the Omega rear end similar to the GTO's ??
Are the diffs similar ??
Old 11-20-2006 | 02:28 PM
  #219
Pete 1's Avatar
The actual suspension arms and main cross member are identical, the diff casings and mountings are totally different tho, and the overall width of the GTO axle is 110 mm wider than the Omega, 70 mm of this, is the difference in the diff casing.
Old 11-20-2006 | 02:36 PM
  #220
Interesting that parts are the same !!
