ls1 in second gen help
Old Mar 4, 2006 | 08:01 PM
sstz28's Avatar
Default ls1 in second gen help
well we had a 5.3 but know we got an ls1 block. the question is fuel. we are going the external fuel pump route just cause its easier. can any of u guys tell me what pumps ur running n fuel pressure regulators. thanx
Old Mar 5, 2006 | 05:07 AM
sstz28's Avatar
i need help
Old Mar 5, 2006 | 12:12 PM
Schitzo's Avatar
aeromotive should have a pump you can use.....just look for a pump that can provide enuf pressure for the engine....I think 60psi+ should be ok.
You can use a corvette fuel regulator
what fuel system do you have for 5.3 anyway.....why wouldn't that work?
Old Mar 5, 2006 | 01:23 PM
Stu Cool's Avatar
The FAQ and search engine are your friends, this has been discussed a lot:
External Fuel Pump
https://ls1tech.com/forums/search.php?searchid=2854228
Fuel Pump
https://ls1tech.com/forums/search.php?searchid=2853980
Fuel Pressure regulator
https://ls1tech.com/forums/search.php?searchid=2854238
Hope that helps
Pat
Old Mar 5, 2006 | 01:43 PM
Lesrace82's Avatar
I have had bad luck with the aeromotive inline pumps. had the EFi pump and it ate itself in about a 1000 miles. Now I run the Bosch 420L inline pump with no problems.
Old Mar 7, 2006 | 10:51 PM
sstz28's Avatar
thanks guys. im a newbie when it comes to conversions.
Old Mar 7, 2006 | 10:53 PM
sstz28's Avatar
the 5.3 wasnt in we were going to put it in. but got a good deal for the ls1
Old Mar 8, 2006 | 01:42 PM
Schitzo's Avatar
you can go to my homepage and see what I did for the fuel system for my 71 (page 2)
Old Mar 9, 2006 | 08:52 PM
71Z28LS1T56's Avatar
I want to put the 2000 camaro pedals in my 71 camaro. Does anyone have any ideas how I should start. It has a clutch and all the linkage.
Old Mar 10, 2006 | 01:27 PM
OldSchoolFormula's Avatar
71 - check out what this guy did. The site hasnt been updated in years, but...
http://www.geocities.com/thelastcaboose2/
Old Mar 14, 2006 | 11:12 PM
thaks a lot. I will try what he did.
Old Mar 15, 2006 | 03:37 AM
Aceshigh's Avatar
External Fuel Pump
Fuel Pump
Hope that helps
Pat
None of those links work. Just FYI.
