VATS and BCM
Thanks Johnathan
Start tracing wires... check the starter relay and see that you have power in the right places.
The reason I ask is that the VATS was malfuctioning on my father inlaws 95 monte carlo . It would not spin the engine when I unpluged the VATS wire on the collum . I thought I read on here long time ago it could do ether Not let the engine turn over or turn injectors off.
Thanks for everyones responce
Johnathan
BTW the big purple wire is the output of the starter relay which controlled by the small Yel/Blk wire.
I assume you've already checked power and grounds to the starter and also bench tested the starter to make sure it's good?
Also does anyone know Where and if theres a fuel pump relay .
Thanks for your guys help .
Another option would be to bypass the starter relay. The relay is located behind the dash on the passenger side, just to the right of the glove box, It is in a hard place to get to. Unplug the relay and jump the purple and yellow wire together. Note that your neutral safety or clutch switch will not work if you bypass the relay.
The Fuel pump relay is located behind the driver kick panel.
