V6 to V8 swap questions
Old Mar 15, 2006 | 10:37 PM
The1N_only's Avatar
Question V6 to V8 swap questions
ok i have a 98 V6 Firebird and i have a Motor, t56, computer, and engine wiring harness out a 2000 trans am... what kind of small problems i might run into... beside the normal stuff like k member... im talking more like electrical or other problems others have run into in the past... ive done searches but i havnt found too much info on it.... Any info would be appreicated
Old Mar 15, 2006 | 11:36 PM
The1N_only's Avatar
Am i going to have problems with my gauges reading??? or something of that nature... anyone?
Old Mar 16, 2006 | 12:13 AM
jmarek78's Avatar
Your best bet would probably be to replace the gauge cluster, but it seems somehow this guy made it work:
http://www.dxsoftware.com/magnus/
Old Mar 17, 2006 | 01:29 PM
The1N_only's Avatar
ttt .... anyone done this before?
Old Mar 17, 2006 | 01:43 PM
v6noobie's Avatar
try camarov6.com, I think a couple have done an ls1 swap, they probly have some good info about it, great site.
Old Mar 17, 2006 | 08:45 PM
joking511's Avatar
Im almost done with my Ls1 transplant in a 94 camaro . I have some sites saved on my other computer Ill post them up when I get on it. If I where you I would sell your PCM and wiring harness and get 98 PCM and harness . it will almost be plug and play .
Old Mar 17, 2006 | 11:12 PM
sercastiK's Avatar
id use the whole wiring front to back..
J
Old Mar 19, 2006 | 12:57 AM
homegrown TA's Avatar
If i were you I would just buy an ls1 car. i've done it, and if you use a LT1 guage cluster the speedo will work, but the tach will only read half of what the actual RPM's are. if your running headers....get the ls1 rack and pinion, with the knuckle. not sure exactly what you are needing to know, but pm me anytime, i may be able to help.
Old Mar 19, 2006 | 09:40 PM
The1N_only's Avatar
Ok well this is what i have so far... LS1, t56, Engine wiring harness, computer, k-member, radiator hoses and fans, rack and pinon along with the steering shaft, headers, plastic fuel tank, and gauge cluster out of a 2000 trans am... im pulling the entire HVAC out.... what im more interested in is the wiring part of the swap and what all is involved... this is all going in a firebird... and no im not going to go out and buy a ls1 body... I dont have the money and i have a perfectly good hard top in my driveway thats itching for an ls1 ... i just want to know some of the problems that some of your guys have ran in to and what you did to solve them. thank you
Old Mar 20, 2006 | 12:31 AM
ArchOverseer's Avatar
I did the swap. Had a 2000 V6 Camaro (A4) and swapped a 99 LS1 w/ Tranny (A4) out of a 99 Trans Am into it. It wasn't that difficult a job, really. A new k-member is needed, along with a new radiator....We didn't even bother with the air conditioning crap, so my car's without it, for now. The car needed a new lid, a new Y-pipe as well. The stock V6 gauge cluster worked for me for a good while, but I got tired of pegging it at 120 and not knowing how fast I was going, so I opted for a simple gauge cluster swap outta an 2000 Z28. A mechanical accelerator pedal is also going to be needed, because the V6 is ETC. The only real problem we ran into was the fuel problem. Everyone knows LS1's are returnless style, and have the regulator built into the tank. The V6 of course has a return line, with no regulator in the tank. We ended up keeping the V6 gas tank, and swapping a set of 97-98 Corvette fuel rails with the return line hookups on them, hooked the return line up and never had a problem. I suppose it might've been easier to just ditch the return line and buy an LS1 fuel tank, but we decided to do it a different way. We didn't have to change the rear because my car was ordered with a limited slip, 3.42 rear axle... Hope any of that helped.
Chris
Old Mar 20, 2006 | 12:00 PM
The1N_only's Avatar
well i have long tubes and duals that are going on it so my exhaust isnt going to be an issuse.... what all do i need to convet to the returnless fuel system... i have the fuel tank out of a 2000 T/A.... am i going to have any problems with the sender because i read some where that they changed it in 99.. but if i run a 2000 gauge cluster would that change anything? and also the wiring going up to the cluster... and i going to have to rewire it becuase it is pinned out different or what?
Old Mar 20, 2006 | 11:30 PM
The1N_only's Avatar
ttt for the night
