ls1 in a 93 3.4 v6??
LT1 into a V6 F-body '93 - '97 Parts needed:
LT1 and V8 Transmission (none of the F-body
V6 Transmissions will work behind the V8)
V8 Front Suspension Crossmember $150
(Each engine had different motor mount holes)
Engine compartment wiring harness $150
(different from the engine wiring harness)
Dual fan setup '93-'95 $140
V8 Exhaust System
V8 Heater Hoses $40
V8 Fuel Lines (LT1) $50
1 piece driveshaft $75
Aluminum driveshaft $175
V8 Gauges $75
Recommended:
Limited Slip Differential with disc brakes
LS1 into a F-body '93 - '02 Parts needed:
LS1 and V8 Transmission (none of the F-body
V8 Heater Hoses $40
Will need '97 Corvette fuel rails or rails modified by Street and Performance
to hook up the stock lines or an external pressure regulator.
Due to electronics changes from year to year and difference in V6 & V8 cars,
it is impossible list all the different changes and mods that would be required
to be made to install the LS1 in a V6 or LT1 car.
i've done a 98 v6 to 98 ls1 convertion
if you have a donore car then a swap would be pretty easy part for part
you have to change the fuel pump soo it should be easy other than that i even swapped the fuel lines
