Egr
Old May 9, 2006 | 05:24 AM
PaulFLS6's Avatar
Default Egr
I have taken the EGR off my LS6 engine. When I capped off the hole in the manifold the engine started throwing out brown/black smoke, which I assume was because it was running in full rich mode.
Opened the hole in the manifold and the engine ran clean again.
Is this normal, or is there something else I need to be looking at?
Old May 9, 2006 | 05:27 AM
robin427's Avatar
Paul, wasn't it the EVAP system that you capped off?
Old May 9, 2006 | 04:08 PM
Happy Jim's Avatar
Which manifold are you talking about? in/ex
Old May 10, 2006 | 01:47 AM
PaulFLS6's Avatar
The inlet manifold
Old May 10, 2006 | 05:53 PM
shr00m-dew's Avatar
The LS6's never had EGR. Not exactly sure what you are removing.
Kevin D.
Old May 10, 2006 | 06:00 PM
Happy Jim's Avatar
Paul,
Have you got a picture of what you removed? - either way, a hole to atmosphere in the inlet manifold would be a baaaad thing! (unless it's known as the TB of course).
Jim
Old May 10, 2006 | 09:07 PM
Phoenix 5.7's Avatar
the EGR is the tube goin from the passenger exhaust mani to the intake mani just behind the TB, just to clarify.
When i removed my EGR, it didn't affect my car at all as far as how it ran.
Old May 11, 2006 | 10:44 AM
PaulFLS6's Avatar
This is what I removed
Old May 11, 2006 | 10:46 AM
motopsychoz's Avatar
That is your evap
Old May 11, 2006 | 11:13 AM
67RSCamaroVette's Avatar
so when you plug the hole you get black smoke?
Old May 11, 2006 | 01:05 PM
robin427's Avatar
Originally Posted by motopsychoz
That is your evap
So, I was right!!
Old May 11, 2006 | 01:18 PM
70 LS1's Avatar
Conversion master
I left the EVAP valve in place and disconnected the hose. Pretty much the same as removing the whole thing and plugging the hole. No smoke here. So I would say something else is wrong.
Old May 11, 2006 | 01:56 PM
MrDude_1's Avatar
go open your fuel tank cap, then restart the car with the line disconnected and intake capped.
Old May 11, 2006 | 05:18 PM
Happy Jim's Avatar
Might be worth removing the PCV and plugging that hole then re-try (Evap hole plugged). You may be sucking oil into the intake and burning that?
Just a thought
Jim
Old May 12, 2006 | 05:16 AM
PaulFLS6's Avatar
Does anyone think the problem could be caused by a faulty fuel pressure regulator. I have got a gauge on the regulator, and if it is correct I have too much pressure. I have tried adjusting it to reduce the pressure, but the gauge still indicates too much pressure.
After a minute or so on tick over, the fuel pump starts working harder until the fuel pressure drops to 58 psi and at the same time the engine cuts out.
I presume that if the gauge is correct the engine could be running too much fuel, hence the smoke. Unplugging the evap hole may be allowing more air in and allowing the engine to run leaner.
Just a theory, but does it make any sense?
Old May 12, 2006 | 05:19 AM
robin427's Avatar
When I had mine checked at GD, the 58psi was set for the moment the system is pressurised when the key is first turned (i.e. before engine start). Don't know how the pressure varies whilst the engine is running...
Old May 12, 2006 | 05:51 PM
Happy Jim's Avatar
Paul,
Does sound as if the regulator could be suspect. Might also be worth removing the filler cap to remove any chance of a blocked fuel tank breather causing the problem. Or maybe a hose collapsing therby causing loss of fuel (hence speeding up the pump) - straw clutching maybe?
Jim
Old May 13, 2006 | 05:39 PM
robin427's Avatar
Why do we add the extra regulator - what would happen if the pump was connected directly to the fuel rail - could it cope with the back pressure from the engine regulator?
Old May 13, 2006 | 08:33 PM
the fuel pump would burn up. The fuel has to go somewhere.. if its deadlocked, the pump will have problems. What do you mean by "second" regulator?
Old May 13, 2006 | 11:32 PM
70 LS1's Avatar
Conversion master
97 and 98 corvettes had the regulator on the fuel rail. With these, you don't need the regulator near the pump.
98-02 F-bodies and 99+ vettes don't have the regulator on the rail and you have to use a different regulator, a lot of guys use the 99-03 Corvette regulator.
