Cj7 Finally On It's Way
Thank you for your help HUMJ7
How did you do with the front drive shaft? The oil pressure line is a an-4 from older aircrafts. Lines used on aircrafts are now MS type fittings. A lot of AN- stuff is all around if you can find it. I found it on E-bay. The adapter size for the mechanical water temp is 3/8-18 which came with the gauge. You need to tap that 12mm hole. These two mechanical gauge set up are the REAL McCoy, it shows true values all the time. To test the accuracy we checked the readings with the OBII. Good luck!
Thanks
Mikkofin, I used the original stock pan fron the truck. No encounters so far. It looks as if it belongs to the Jeep.
Thanks
thanks to all of you for your help! one question there is a small coolant line that runs under butterfly on front of engine not sure what it's for ? I looked at one of these motors in a freinds truck and it goes into radiator . My radiator does not have a place for this hose to go into I was wondering what the line is for and what you did with yours ? Possibley run it to over flow tank ? Did not drive jeep because in middle of ground up restoration. THANKS AGAIN FOR YOUR HELP!
Thanks
When you reflashed your ECU did you keep the mode that controls the tranny? so like when you floor it does it down shift automaticaly?
Im debating between that or a TH350 tranny. I will be doing this on a 90 YJ do you think the NP231 can handle the 5.3 thanks?
Thanks
Thanks
I have been extremly busy with home projects,home business,Beating the s--t out of my other jeep will send pics. when i can sorry for the delay HUMJ7
O.K. these don't look like yours when you click on them can some body help me with attachments ? THANKS HUMJ7
Thanks
I'm in the process of putting a 06' 5.3 in my CJ5. Where did you get your radiator and fans? How do they cool?
Did you keep the power steering pump? If so how did that pan out?
I'm ready to get this thing fired up. It should be a ride.... The motor is the all aluminum 310hp set up for the 06' work package. Plus, the CJ is all fiberglass. As light as all of it is, it should be a handful to drive.
Thanks
