Cj7 Finally On It's Way
Seems like it did remain in the stock position in the first photos.
What auto tranny have you got?
Thanks
Why I am asking this is that it may be that I am changing in axles that have a quite a long pinion (nose) and the transfer case should remain in stock position to be able to do this.
Thanks
Have not done much with the jeep because of hunting season . But need to get going because my finsh build date is 4/1/07 alot of work to do before then. HUMJ7
Thanks
I have it wired so i can here it run for inspiration.
THANKS FOR THE HELP
HUMJ7
Can you please tell me where you got your throttle cable? maybe part#?
Also you said you had more throttle response with air box did you fab.? a box or buy one. If brought where and part# please. Well body is off to painter.I'am putting finish touches on drive train stuff like painting sterring shaft. brake booster, rad.frame steering colum.Putting fluids in front rear axles, transfer case. How is super charger going?
PS,This weekend we have had 15 inchs of snow with blizzard warings.Temps around 0 to -7 below sure makes Hawaii sound good!
THANKS AGAIN, HUMJ7
Thanks,
Pick01
Humj7
THANKS AGAIN, HUMJ7
Thanks
Thank you! I did end up buying a lokar cable.Bought all the stuff to make my own air intake. Just got done wiring the jeep. Leds gave me a little promblem,figured out you need a led flasher for the blinkers when you run leds.I am so close to being done I can taste it.
So, what is this Subaru Eating Bug?
Humj7
Thanks, for coming back and replying.
