HELP wont start!!!!!!!!
Old Jun 30, 2006 | 08:16 PM
joking511's Avatar
Default HELP wont start!!!!!!!!
OK Ive been converting a 94v6 car to 98 ls1 for a while now. Ive got all ready to start (so I thought) I've mated the 98 engine harness to the 94 body harness,Vats has been removed, I have good fuel pressure, the ecm powers up(or the check engine light comes on with the key anyway) Is there some way to check to see if its not firing or if the injectors or not firing. I remember reading long timeago the coil packs had to be put back on the same side the come off of . I dont know if they did.
Thanks Johnathan
Old Jun 30, 2006 | 10:24 PM
94redz28's Avatar
I am about to start the same swap, how hard is the wiring? Have you pulled a spark plug to see if it has any fuel on it?
Old Jun 30, 2006 | 11:20 PM
joking511's Avatar
Its wasnt to bad. Ive got the pins I swaped in an M/S works spred sheet. I'll try to post it tommorrow When I get home?
Old Jul 3, 2006 | 09:24 PM
joking511's Avatar
Anyone have any Ideas!!
Old Jul 4, 2006 | 03:34 PM
joking511's Avatar
OK I did some checking today. I hooked autotap to it. had no codes.
Pulled a spark plug its dry
unpluged the fuel pump and cranked the over and had no drop in fuel pressure . So its got to be that the injectors are ont firing but why?
Old Jul 4, 2006 | 05:48 PM
91sbcamaro's Avatar
Same thing happend to me, go down and verify that your CrankShaft Position Sensor is plugged in, and your Camshaft Position sensor is plugged in. Those are the 2 things that have to be working to start your engine.
Old Jul 5, 2006 | 10:56 AM
kwkenuf's Avatar
How long has your swap motor been sitting until you tried to fire it? The injectors are prone to gumming up if left unused for a long period of time. This happened on both my F.I. swaps, an LT1 and a 5.3. If you suspect this is the case, disconnect each of the injectors from the harness and apply 12V and ground directly to the injector pins. Remove and reapply voltage until you hear the injector click, then move on to the next one and repeat.
This is a very common problem on engine swaps that have been sitting a while.
Old Jul 5, 2006 | 12:42 PM
joking511's Avatar
I'll try that. I know Its been setting a year that I,ve had it. Who knows how long before. Thanks for the idea!!!!
Old Jul 9, 2006 | 03:09 PM
joking511's Avatar
Ok I checked with autotap today. I have no CAM singal or oil pressure singal. Is it possible that I swap the plugs when I put the harness back on or will they not interchange.
Old Jul 9, 2006 | 10:41 PM
G-Body's Avatar
sawzall wielding director
The plugs are not interchangeable. The no oil pressure should not stop you from starting it, but the cam pos sensor will. Start by checking that it is plugged in and that the wires between it and the computer are good.
Old Jul 9, 2006 | 10:54 PM
67RSCamaroVette's Avatar
cam sensor and crank sensors will both prevent the car from firing up. +1 to what g-body said.
