Opinions on C6 Z06 wheels on Chevelle...(pic)
Well a couple guys came up w/ this pic for me. Next is to have someone do it in the C6 Le Mans Metallic Blue w/ the hyper chrome wheels below... What do you guys think?
Jason
Jason
Originally Posted by alocker
Its not bad, but I tend to prefer a wheel without so much positive offset. I think you need deep lips to look right on a 60s and 70s muscle car.
Deep wheel won't work on a C5 chassis underneath. Also the offset of these will be better for handling. I would rather have some like Fikse's or something but this will get me started. I can get the hyper blacks in 18X9.5(f) and 19X12(r) for $990 vs. Fikse for like $3-$4K.
I just figure w/ the overall theme of the car these fit well. It will probably end up having a C6 dash/seats in it and will also have the C6 Z06 brakes. If it was a carb'd Chevelle and orig style interior I would definately go w/ dished TT II's, Boyd's, Foose, etc...
Thanks for the opinions!
I like it, we're not talking about some 454 SS car or something. It's a Chevelle with a LS2 and it's pro-touring. I'm all for it, if I had to refocus on my '69 I'd have some C6 wheels on it...
could be the photoshop but those wheels don't look quite right on a chevelle. The chevelle is a robust car and needs wheels that complement that aspect of it. Those seem like they would give in under the chevelle. just my 2 cents.
have you tried this wheel? It might look alittle different on there.
Originally Posted by stealth71
I would buy a set, but running a huge spacer seems like a pain.
And I'll have to try those wheels out Schitzo.
Don't run a spacer, use adapters. They bolt on and have the same bolt pattern. Just use good studs allte way around and you'll be plenty safe. Search the net, I think you need about a 3-3.5 inch adapter. Try pro-touring.com or lateral-g.net
--JMarsa
--JMarsa
