Another ls1 startup video
Old Aug 6, 2006 | 09:45 AM
jimmyp's Avatar
Default Another ls1 startup video
Got my Ez wiring harness hooked up along with a universal ignition switch. Started right up! Video is not very good and the camera couldnt handle the noise inside the garage. But it seems to be idling kind of high right now..any idea why? All I need now is brake pads and I can take it for a test drive!
Old Aug 7, 2006 | 09:33 PM
01PewterWS6's Avatar
Sounds good!
Old Aug 7, 2006 | 10:21 PM
Stu Cool's Avatar
Way to go Jimmy! It make take the computer a little while to figure out where to idle, if it does not idle down soon, then check for vacuum leaks.
Pat
Old Aug 7, 2006 | 10:54 PM
67RSCamaroVette's Avatar
sweet! look for vacuum leaks or at the throttle body to see if it's cracked at all. Could take a few learning cycles to drop down, too. good luck, and congrats!
olly
Old Aug 8, 2006 | 02:16 PM
nitrovette's Avatar
Sounds good congrats,mine took a bit to learn idle too ,its been fine since.
Old Aug 8, 2006 | 05:07 PM
jimmyp's Avatar
thanks guys...
As far as the idle.. is it better to have it start and stop multiple times or is it better to have it run for a long period?
Is there a good method for checking for vacuum leaks? I know if you are checking for pressure leaks soapy water does the trick.
Old Aug 8, 2006 | 08:46 PM
carb cleaner/ ether. dust it around the engine, at the booster, etc.. and listen for an increase in RPM.
Old Aug 9, 2006 | 09:33 PM
StevenK's Avatar
Dude, you put your door on backwards! ;-)
sounds good man, welcome to the club
Old Aug 9, 2006 | 10:32 PM
LSxChevelle's Avatar
Well at least he can do a motor swap. Congrats and it's looking great. Just do what the guys above said...
