Wire Harness Loom protection
Figured I would ask here 1st, sense most have to rework there wire harness,s for conversions ect.
Looking for some high quality wire harness protection.
Some call it convolated tubing, I am sure there are other names as well. Any Idea who has a selection of high quality stuff, with options for the larger size,s. Local auto parts stores only carry the small size 1/2 or so. Which I have found not to to hold up to well.
Also would like to find the wrapping tape which dose not unwrap after time like normal black electrical tape will do.
We carry it where I work, but we're not a retail outlet -- we're an industrial maintenance supply house with route salesmen. If you can't find it anywhere else though, I can probably buy it myself and ship some to you. We have sizes up to 1 inch in 50ft. or 100ft. bundles, black only of course (large maintenance shops don't care about ricing out their equipment)
Sounds good, Do you have a link for related info?
What about the tape any word on that as well. Looking for some of the black self fusion type.
Nope, no link for info, and I don't think we carry the tape.
Have you checked with our wiring harness sponsors (Speartech, American AutoWire, etc.)? I'm sure they have plenty of this stuff too, and they'd be a lot easier to order from. Likely cheaper too, our prices are kinda high.
Originally Posted by kosmo38
just go to the junk yard.
so now I need to find somewhere else to get it. Thanks everyone found a location for some great stuff.
Found some that will with stand temps of up to 300 def F. They also have Tee,s couplings, clamps ect.
Here is a small sample of what they stock
http://order.waytekwire.com/IMAGES/M...og/218_102.PDF
http://order.waytekwire.com/IMAGES/M...og/218_104.PDF
Sizes from 1/8 - 2'' IE corrugated loom.
If you shrinkwarp doesn't make the the harness hard and not flexable?
Originally Posted by 67RSCamaroVette
shrink wrap > convoluted tubing.
more weatherproof, compact, etc.. 3M sells it in 100ft rolls, the harnesses look super clean when shrinkwrapped.
Keep in mind there are a couple of grades of split loom. There's the cheap stuff that Harbor Freight sells (low temp non UV protected) and there's the automotive grade stuff.
I got mine at McMaster-Carr (online order, http://www.mcmaster.com ). The nylon is the higher temp stuff. The cheap stuff will turn white and get crumbly pretty darn quick.
Originally Posted by G-Body
The last time I went to the yard for more they wanted to charge me for it
so now I need to find somewhere else to get it. I made a good discovery yesterday. I got 100' of 1/2" and 3/8" split wire loom for $17 and $14 for 100 feet of Each size FROM FASTENAL. They had to order it from the Hub so I got hit with shipping but it was $44 for 100 feet of each size. Got a 50 pack of the Pico harness clips for $22 on Amazon.
Just thought I'd pass the info on.....
I usuall order braided split covering from McMaster-Carr. They have many type from plastic to metal to heat proof.
http://www.mcmaster.com/#standard-cable-sleeving/=ubbwgf
