Another LS14 Project.
Old Oct 26, 2006 | 10:11 PM
  #41
datboibrad's Avatar
Originally Posted by MakotoS13
good work brad. i hope the project turns out well
this project makes me warm inside
Old Oct 27, 2006 | 01:50 AM
  #42
mikespeed95's Avatar
ill make your insides warm..
Old Oct 27, 2006 | 02:03 AM
  #43
datboibrad's Avatar
:X take me for a ride in that blue devil of yours
Old Oct 27, 2006 | 10:21 AM
  #44
i left it in florida, should have brought it back but it was nice cruising at 95mph the whole way here with no trailer
Old Oct 27, 2006 | 11:28 AM
  #45
datboibrad's Avatar
quick pics from this mornings partial dissasembly.
i tell you one thing. these motors come apart and put back together a hell of alot easier than most 4 cylinders.
pulled the oil pan and wasnt to suprised with the results. milky ice cream oil but no one shard or flake of metal!!!
pretty dirty
someone left ice cream on my pickup :p
big ol rear main seal
final result is bottom end loks pretty solid. im very confident to say the motor didnt run with wtaer in it and that it more than likely leaked in from rain into the meteorite impacted valve cover
Old Oct 27, 2006 | 11:29 AM
  #46
datboibrad's Avatar
going to pull main caps and rods to check bearing wear and size up some replacements and drop off the crank and rods sometime next week to get cleaned up and have bearings fitted etc. i need to go ahead and order some ARP rod bolts since lately everyone seems to be spinning bearings like crazy
Old Oct 27, 2006 | 12:23 PM
  #47
Urban Legend's Avatar
TECH Cry Baby BOSS APPROVED!
Good luck.
Old Oct 27, 2006 | 12:41 PM
  #48
datboibrad's Avatar
thanks man
Old Oct 28, 2006 | 01:46 PM
  #49
Schitzo's Avatar
looks good man.....keep it up
Old Oct 28, 2006 | 04:44 PM
  #50
datboibrad's Avatar
picked up a donated ls6 manifold and a bored over ls1 long block. ill get pics up later.
Old Oct 28, 2006 | 05:48 PM
  #51
wow i hate you so much right now!
Old Oct 29, 2006 | 04:48 PM
  #52
datboibrad's Avatar
lol why is that. all ive ever done was take your advice mike
now find me a transmission!
Old Oct 29, 2006 | 10:59 PM
  #53
Slo_240sx's Avatar
Yucky! To be honest I think the engine is okay you just need to flush it out. Since you're walking the walk now, I am at service to my advice on AIM hahaha. Rod bolts, bearings, grind crank, hone block, heads and cam and youre ready to rock!
Old Oct 30, 2006 | 12:54 AM
  #54
datboibrad's Avatar
hehe you sir are on the same line of site as me. ive been trying with no luck to find a part number for a full kit from ARP for the Head, Rods and Main bolt kit but they are different everywhere i go. im ready to get this bitch on the road!
Old Oct 30, 2006 | 12:13 PM
  #55
Slo_240sx's Avatar
I got all the numbers, Hit me up on AIM.
Old Oct 30, 2006 | 02:02 PM
  #56
owen v8litew8's Avatar
eeeeeeeeeeeew frothy goodness.
at least you got time to rebuild it, yeah isnt it cool how fast the LS1 can be torn down and rebuilt? pretty impressive. just remember to NOT lube the rear main seal upon reassembly!!!!!!!!!!!
Old Oct 30, 2006 | 06:45 PM
  #57
datboibrad's Avatar
dont lube? care to explain?
Old Oct 30, 2006 | 08:29 PM
  #58
Ted J's Avatar
Also remember to use three if not four .002" feeler gauges around the outside of the crankshaft to that of the oil pump before tightening it down or you'll be rebuilding the engine again sometime soon when the oil pump goes out!
Old Oct 31, 2006 | 07:28 AM
  #59
datboibrad's Avatar
so i would assume there has to be a gap of .002 between the oil pump and the outside are of the crank shaft after touqred down?
Old Oct 31, 2006 | 08:36 AM
  #60
Ted J's Avatar
Yeah, you put the oil pump on loose and push the four feeler gagues into place around the crankshaft and then you tighten down the oil pump. I'm pretty sure it's .002", that can be double checked though. The big thing to note is that you've got to make sure to do it or else the oil pump will get destroyed from what I've read.
