67 RS/SS getting a little LS2
I have just removed a pretty good BBC from my RS/SS to put in a real racecar. I have now a complete 2006 CTS-V to use for my swap.
The car already has a T-56 so I hope the issues with the shifter and driveshaft are already taken care of. I need to swap in the T56 from the caddy though as the big block didn't do nice things to the trans in it now.
I am going to be using these to mount the engine cheap fix I saw these in the great sticky.
I am ordering these headers if no one has a better idea. Hooker
The drive by wire issue has me a bit flustered but I'll try what I read and just steal the pedal and associated wiring.
I am still investigating the computer issue. I know the current one will need to be modded to run outside the CTS. The wires don't look too bad, I will try modding the stock harness to work in the Camaro. If I fail then I will investigate alternatives.
Since I have the whole car I am going to see about using the stock tank. I haven't seen anyone try it yet so why not.
I realize so far this is a boring thread so heres a pic of the donor car
and the heart
Oh and I have a Be-Cool radiator/elec fan for the Car. Should I use the one out of the caddy and sell the Be-Cool or visa-versa?
Thanks!
Thanks!
you'll need the frame "stands" from a SBC car. You can use solid motor mounts if you want, although without modifying how the knock sensors work, it may cause problems. i'd get some nice Energy suspension interlocking graphite embedded ones. (without the spacers)
2. I'd keep the beCool. theyr'e nice radiators, so find a hose setup that will work for you (either use like -20AN hose) or do like I did and find an OEM hose that fits from VatoZone, Napa, etc.
keep the be cool
the motor mounts on the frame need to the the small block ones....the uppers use urethane in combination with whatever adapters you use
The car was a 10 second street car on juice but I want desperately to have this be a daily driver.
The caddy was crushed by a rather large tree. I looked into having it repaired and the body guys found it needed much more than just a roof.
And to the OP, good luck and keep us posted, I would love to have that setup.
It's called thier double-pass LS1 swap radiator.
