Entire Engine Wiring Schematic
Old Dec 1, 2006 | 11:47 AM
1point3liter's Avatar
Default Entire Engine Wiring Schematic
Hello,
I've done a ton of searching but have not been able to find an entire engine wiring schematic. I'm building a custom harness for use with a non standard engine management setup so the pin-outs don't really tell me much.
I preferably need the schematic for a 98-2002 fbody, but it probably doesn't matter as long as it's for a some sort of LSX engine. Anyone have what i need or know where to find it? I see people posting various schematics for fog lights etc so someone must have this information.
I got one for a 99 fbody a few years back but i can't seem to find it.
Old Dec 1, 2006 | 12:01 PM
bczee's Avatar
Check the GM LS1 Installation guide / manual
Old Dec 1, 2006 | 12:13 PM
where can I find the GM LS1 Installation guide / manual? Is it online anywhere?
Old Dec 1, 2006 | 01:02 PM
bczee's Avatar
you can buy one at any GM / Chevy or gmpartsdirect.com, note.. it is setup for the LS1 create engine and PCM .. based on 98 harness and pcm. but it should give you a good idea of what you need.
Old Dec 1, 2006 | 01:12 PM
happen to have a part number?
Old Dec 1, 2006 | 01:16 PM
hmm ...i was hoping for a pdf or tif etc.
Old Dec 1, 2006 | 01:56 PM
busta9876's Avatar
I uploaded all the engine controls schematics I have to my website
www.lt1swap.com
look for 2001 Camaro Schematics about 1 page down.
if you need anything else let me know.
Old Dec 1, 2006 | 02:17 PM
G-Body's Avatar
sawzall wielding director
So far I have not seen a single complete schematic for the engine. All of the GM manuals that I have seen and the alldata schematics show portions of the engine wiring. If you look at all of them you will end up seeing every wire, but I have not seen a schematic where every wire was on one page. It is possible that the GM install manual has a schematic like that, but I don`t have the manual so I can`t confirm that.
The year of the schematic will end up mattering, the 98 computer has radically different pin outs than the 99+ so you should get a schematic for whatever year computer that you plan on running. You could do it with the wrong year schematic and pinouts for both years, but only 6 wires or so are in the same place so that would be a lot more unnecessary headaches.
Old Dec 1, 2006 | 02:45 PM
www.lt1swap.com
Excellent! Thank you!
Old Dec 1, 2006 | 02:49 PM
im building a custom harness to use with an AEM EMS so im not worried about the different year pinouts. I just need a detailed break down of how sensors are wired.
Old Dec 1, 2006 | 02:51 PM
busta9876's Avatar
the schematic I posted is directly out of GM Service Information, same thing GM dealerships have. That is most condensed they get from GM.
