5.3 iron blocks bored= 5.7??
Is it possible to have a budget build up using a 5.3 liter motor and do the following? Thus making it a 5.7 liter iron block? Any benefits? Will it make just as much power with bolt ons as a LS1? or less? can it handle more nitrous?
What are the pros and cons of doing this? Becuase this setup can be put together for pretty cheap... just need your opinons
Iron 5.3L Block (Over bored to fit 5.7L LS1 Pistons)
10/10 Gm Forged Crank
Speed Pro Competion Series Main Bearings
Speed Pro Competion Series Rod Bearings
Gm Cracked Rods
Speed Pro Hypereutectic Coated Pistons
LS6 High Flow Oil Pump
Speed Pro File to fit Plasma Moly Piston Rings
Custom Crower Cam
Chrome Moly Pushrods
.600 lift Beehive Valve Springs
Comp Cam Lifters
2002 LS1 241 Cylinder Heads Milled .030 with stock valves and GM Seals
VR Performance Composite Head Gaskets
Complete Engine Gasket
Powerforce Balancer
![](http://i30.photobucket.com/albums/c304/mrbustamove2003/5.jpg)
Gm Cracked Rods
Custom Crower Cam
Comp Cam Lifters
Powerforce Balancer
![](http://i30.photobucket.com/albums/c304/mrbustamove2003/53.jpg)
This has been done plenty of times and is well known about. The thing is that you have to bore it out a bit to get 5.7L which will make the cylinder walls a bit thinner, which can lead to weakening. I am sure if built and tuned right it would be very reliable. Keep in mind tough that the 5.3 block is also iron which is much heavier then the aluminum LS1. Thats why i am just gonna spend the extra $$ on the ls1 block, i dont want to add weight to the car.
