So here's the game plan 00 Mustang + LSx + huge turbo :)
Old 11-27-2007 | 03:55 PM
  #461
Fast895ohstang's Avatar
awesome project man...im subscribing as i just read through all 23 pages
Old 11-28-2007 | 10:13 AM
  #462
kirtondog23's Avatar
This will be nice to see completed! First rate build. You have thought through everything!
Old 11-29-2007 | 10:40 AM
  #463
ReiKo's Avatar
Thanks for the update...
Old 11-29-2007 | 03:57 PM
  #464
slammer454's Avatar
can't wait to see it painted!
Old 11-29-2007 | 08:49 PM
  #465
Phil99vette's Avatar
7 Second Club
I'm about 3/4 of the way through my final punch list of things to do before it goes to paint. The stuff is mostly small BS stuff but needs to get done. Got all of the necessary holes drilled for wiring harness, fuel lines, wires, ect. Got the accusump mount done, the interior of the car is done, all of the floor pans are now welded to the bars and sealed.
Old 11-29-2007 | 10:39 PM
  #466
bonecrrusher's Avatar
What are you using to seal the floor pans where the bars go through??
Old 11-30-2007 | 09:13 AM
  #467
7 Second Club
They were first welded to the floor pans and than we used a seam sealer. The stuff came from eastwood.
Old 11-30-2007 | 04:55 PM
  #468
sloganish's Avatar
this thing is ******* sick
Old 12-02-2007 | 08:23 PM
  #469
7 Second Club
Speechless...
Old 12-02-2007 | 10:00 PM
  #470
Cam72aro's Avatar
Is the accusump just an oil accumulator? Or is it something else?
Old 12-02-2007 | 10:39 PM
  #471
7 Second Club
Yeah its an oil accumulator. Hopefully it will prevent the motor from starving for oil when the RPMs get past 8000. I did a couple of things with the oil pan to help also.
Old 12-03-2007 | 08:46 PM
  #472
Cam72aro's Avatar
Cool man, 8000 rpms with that turbo should make some serious power. You plan on running limited street with it or another class?
Old 12-07-2007 | 02:40 PM
  #473
slammer454's Avatar
looks SICK! as mentioned above, what class is the beast going to run in?
Old 12-07-2007 | 05:31 PM
  #474
LSfan70s's Avatar
Thumbs up
Originally Posted by Posi12Bolt
And me too....
Old 12-07-2007 | 11:22 PM
  #475
7 Second Club
First coat...
Second coat..
Custom aluminum radiator hose
Old 12-07-2007 | 11:33 PM
  #476
7 Second Club
I'll be running a local drag radial class and stick to the drag radial stock suspension venues.
Old 12-08-2007 | 12:30 AM
  #477
irbs's Avatar
Looks like its gonna move. The stance looks good.
Old 12-10-2007 | 12:12 AM
  #478
7 Second Club
Didn't get much done this weekend...
- Used a piece of 6" aluminum tubing 18" long, cut a 1/2" section out to make a inlet on the bumper for the turbo. Got the bumper cut and than trimmed the aluminum tube so it contours the bumper
- Milled ~.015 off the back of the pistons, just used a round aluminum burr and milled a groove between the wrist pin, have about .020 of clearance now
- Cleaned the block for assembly
- Cleaned/Hung the rods on the pistons
- Tig welded reluctor wheel to crank
- Dropped the crank in the LSx block, installed main caps and completed 2 torque sequences
- Drilled remining holes in the valley cover and pre-fit 1/8" bung for oil pressure
- Ground off fill tube from valve covers to weld on Aluminum fill bung and cap
- Touched up a couple areas on the cage where the paint was thin
- Mounted fenders and front bumper back onto car to go to paint
I'll get some more work done tomorrow morning before work.
Old 12-10-2007 | 12:49 AM
  #479
LuvmyC5's Avatar
It's coming along Great Phil!
I missed seeing the updates on the other forum!
Old 12-10-2007 | 10:12 AM
  #480
T Pizzle's Avatar
Killer progress Phil
Quick Reply: So here's the game plan 00 Mustang + LSx + huge turbo :)
