ls1 harness on ls2 engine , engine not starting !!
Old Jan 10, 2007 | 07:05 AM
TNTaddict's Avatar
Default ls1 harness on ls2 engine , engine not starting !!
everything is the right place what could be wrong??need help your help guys.
thanx in advance
Old Jan 10, 2007 | 07:24 AM
02 BLK WS6's Avatar
Reluctor wheel on the crank is for an LS1 right?????
Old Jan 10, 2007 | 07:36 AM
TNTaddict's Avatar
yes it is.
Old Jan 10, 2007 | 07:37 AM
tunedportcj5's Avatar
What did you do for the cam sensor? did you buy a harness or extend your own? Any codes?
Old Jan 10, 2007 | 10:34 AM
Phil99vette's Avatar
7 Second Club
Some of the extension harness for the cam position sensor had the wires reversed.
Old Jan 10, 2007 | 11:58 AM
yes, the wires from the PCM need to be reversed if you are not using a harness for the LS1 > LS2 swap (the harness should already has the pins swapped)
Just switch the outside wires, pin 1 and 3 and leave the middle alone. Of course if you havent already done that!
Old Jan 12, 2007 | 10:45 AM
TNTaddict's Avatar
i think this is my problem does anyoneknow how to fix it?
i swaped the cam sensor wiers 1 with 3 nothing happened:S
Old Jan 12, 2007 | 01:44 PM
What color is your cam sensor?
black = 24x
tan = 52x
Old Jan 12, 2007 | 04:56 PM
digitalsolo's Avatar
Just to play KISS here.
You have fuel and air, just no spark, correct? Do you have tuning software or a tach? Any spare parts to swap? I've had a crank sensor puke and cause this.
Old Jan 13, 2007 | 10:46 PM
screamin seeman's Avatar
Is the cam sprocket for an ls1 as well?
Old Jan 14, 2007 | 09:30 AM
TNTaddict's Avatar
thanx alot guys....finally we fire it up today....
the problem was form the harnesses it self....by the way it's 240sx with an LS2 and G5x3 MTI heads...T-56..with 4.10...and about 2500 lb (full wt.)
will post some pics for the conversion soon..
thanx again guys...
