stock jeep wrangler 4.0L radiator good enough for LS1?
ok, so i know a guy thats running a 5.3 vortec with his stock jeep 4.0L radiator..
an adapter company (when i just tried ordering their electric fan made for the wrangler) said that the stock 4.0L most likely will not be able to cool off the 5.7L.. and that i should buy their 560 dollar radiator...
true?
true?
I just finished the same project - LS1 into a '97 wrangler - and went through the same dilemma. After doing some research and giving it some thought, I think the stock radiator is probably not up to the task of cooling the bigger motor. But then again everyone also said the stock AX-15 trans wouldn't hold up either, and maybe it won't, but so far so good! I guess if you want to save a couple bucks it's worth a try, if it doesn't do the job changing out a radiator doesn't take a whole lot of work. I went with an Advance Adapters radiator - part #716693-AA and the quality is oustanding, but it doesn't come cheap.
Good luck with your project, let me know if I can be of any help - what trans are you using?
A couple specs on mine
'97 TJ
5.5" RE long arm lift
35" SSR tires
LS1, 5-spd
4.88 gears
Full float locked D44 rear
f+r line locks
fuel cell
lockout front hubs
9000lb winch
Autometer gauge cluster
'97 TJ
35" SSR tires
LS1, 5-spd
4.88 gears
f+r line locks
fuel cell
lockout front hubs
9000lb winch
Originally Posted by matthimself456
Try it. If the motor runs hot then spend the cash.
How hot do the 5.3's run stock? The LS1's normally run what I'd call ridiculously hot. The stock tune doesn't even turn on the fans in low-speed mode until 219F, and doesn't crank them all the way up until 234F. At those temps with my old smallblock I would have been towing the car home! I'd image the 5.3 is about the same.
Radiator for 5.7
I've got a 4.8 in a 98 Wrangler. Stock HD 4.0 radiator works great.
98 degree weather no problem.
I've got a 79 Camaro with LS1 and using a Griffin/Summit universal radiator.
16" Spal fan. Never over heats even at 105 degree in traffic.Fan kicks on at 205 and out at 195. Temp sensor welded into the Radiator tank.
Email with any questions.
