LSX Conversions..
Old Feb 17, 2007 | 04:08 PM
the_merv's Avatar
Veteran: Air Force
Default LSX Conversions..
What are some easy vehicles that have been converted into LSX Cars/Trucks. I am looking for something light with some decent handling. I was looking at a 1984 Corvette. A friend of mine has one, and the Transmission is a direct bolt in cause the mounts match, the Engine mounts would have to be re-done a little bit, and then most of it is custom is like any swap.
If anything can't be found easy, I just might beef up my Camaro with a Moser 8.5" 10-bolt Rear and go from there, I already got the Harness built for it.
Old Feb 17, 2007 | 07:05 PM
eagleuh1's Avatar
are you at the airbase. If so, just about anything should be doable if they have a auto hobby shop. All the tools in the world available to anyone with a little ability.
Old Feb 17, 2007 | 09:57 PM
the_merv's Avatar
Veteran: Air Force
I am, and I use that place all the time, trust me.. I have my own Tools, just about everything I need to tear the Car apart. You here also?
The question was more directed as in what would be an easy conversion and something that would be cool with a LS Engine in it.
Old Feb 17, 2007 | 10:03 PM
G-Body's Avatar
sawzall wielding director
Third gen f-bodies are easy, not much cutting is needed, and the later ones have electronic speedos from the factory.
g-bodies are pretty easy, same with second gen camaros.
Old Feb 17, 2007 | 10:12 PM
camarolvr69's Avatar
i wish it wasnt so but a lot of rear drive imports...like rx-7, 240sx, etc.
Old Feb 17, 2007 | 11:01 PM
the_merv's Avatar
Veteran: Air Force
A Miata would be a fast little **** with a built 402 in it..
Old Feb 18, 2007 | 03:20 PM
miata weighs as much as an iron 402
Old Feb 18, 2007 | 07:14 PM
eagleuh1's Avatar
No, I'm in Dover Arkansas, Hwy 7. Used the hobby shops when I was in the Navy all the time. Did a 41 Chevy convertable in Hawaii at the hobby shop. Cant beat the equipment they have. I'm working on a 96 Blazer, not to light though. S10 trucks are fairly light though. The work to put engine in isn't that hard either. Available everywhere too.
Old Feb 18, 2007 | 07:16 PM
s10-den's Avatar
there is a ls1 miata on here that just got completed....definatly worth reading about.s10's are easy too
Old Feb 18, 2007 | 08:09 PM
wonder how they fit an ls1 into a miata engine bay
Old Feb 18, 2007 | 09:41 PM
murphy660's Avatar
^there's a ls6 miata in va. if you didn't know
Old Feb 18, 2007 | 09:56 PM
thats gotta be one sick ride
whats it setup for? autox?
Old Feb 18, 2007 | 09:58 PM
murphy660's Avatar
pretty sure its setup for just um straight nastiness lol. i think its has like 420whp
Old Feb 18, 2007 | 10:05 PM
i have to agree, thats a lot of power for a miata
Old Feb 18, 2007 | 10:10 PM
murphy660's Avatar
It's a 383 stroker motor... LS6 block w/ heads/cam
something like 420 rwhp and 450 rwtq.
and supposibly weighs about 2300lbs....
that would make for a hell of a ride
Old Feb 19, 2007 | 06:55 AM
s10-den's Avatar
I wouldnt get in it.Might get run overby a little 4x4.Just to little for me.I watched the vidio of this little monster,to much for me,something to see
Old Feb 19, 2007 | 06:43 PM
7w/aswap's Avatar
93-95 RX-7. They have great handling, and aren't too bad to swap engines into. You just need to get the engine/tranny/harness. Modify the harness, and buy one of the subframes from granny or hinson and you'll be set.
Old Feb 19, 2007 | 07:16 PM
Rick Speed's Avatar
I know I had to go find one of the hardest swaps just to be original
Old Feb 19, 2007 | 07:31 PM
THE_SUPRA's Avatar
^ i must admit taht does look pretty sweet
