3.4 - ls1 t-56 6 speed question! PLEASE HELP!
I'm swapping my old 3.4 out for a ls1 6-speed.....Also,I'm throwing out the old interior to make way for new out of a 2000-02. Since all gauges, engine, trans,computer,radio are being replaced, will I still need my 3.4 harness for anything? I've heard I need a custom harness, but since EVERYTHING is pretty much being swapped, is this still true? Thanks!
sawzall wielding director
If you replace the entire harness with all the fuseboxes and everything else you won`t need a custom harness. But this would be a very involved project, because in order to get all the wiring harnesses to plug into eachother you may have to replace every wiring harness/fusebox in the car. IE: the motor, dash,fuel tank harness, taillight harness, door power window/lock harnesses etc. I`m not sure what harnesses are the same between the v6 and LS1 car, there are probably some parts that are the same and could be re-used, but I do know that it is more complicated than just swapping the engine and dash harness.
Thanks for the info.! Is the Dash harness and the engine harness 2 seperate harnesses? If so, any idea where I could find them and maybe some links to sites where people have done this swap before? Thanks again...I really appreciate your help!
The engine harness and dash harness are 2 separate harnesses. You could try checking the for sale section here, e-bay, or calling junkyards.
Are you going to do this without a donor car? It will get expensive very fast, you would be much better of to find a wrecked LS1 F-Body and then part it out.
There are links in the LSx conversion car website thread, but that was for a 3800 to LS1 swap. I don`t know of anyone who swapped the motor, trans, and full interior into an older car. I think it would be more cost effective to sell the V6 and buy an LS1 car....unless you have a clean V6 body and find a wrecked LS1 car.
I don't plan on using a donor car. I have friends that find all this stuff for me pretty reasonable. The car I have is in great shape, it just has sentimental value to me and I really want to keep it. I figure that I get to keep the car, plus learn alot from doing it myself. Do you know of any threads or links to sites where people have done this swap? Thanks man!
