Ls2-4l80e Chevelle **UPDATED WITH PICS**
Old 04-18-2010, 08:19 AM
  #221
Bowtie70SS's Avatar
Those wheels look sweet!
Old 04-21-2010, 07:41 PM
  #222
john 67's Avatar
Update- had a c charged and is working, purchased rims and tires , had top installed ,built mini console to go between the center console and dash to house some power outlets , have a spot for navagation and satellite suction cups and house some spekers,all lights and signals working., dynamated most of the interior Waiting to get an alignment and a new windshield . I have driven it about 175 miles so far, JOHN
Old 05-13-2010, 11:42 AM
  #223
Durdan's Avatar
i know im digging up a thread that hasnt been posted on in a month now, but what did you end up doing with the coolant tube that comes out by the throttle body? is it going to the fitting on your radiator hose? i know that the GTO had a coolant surge tank from the factory and i'm curious if i should build one for this malibu that i'm installing an LS2 into.
Old 05-13-2010, 09:26 PM
  #224
john 67's Avatar
I got a fitting from Jags that run and installed it into my upper rad hose. I'll try and post a pic soon.
Old 05-13-2010, 09:28 PM
  #225
john 67's Avatar
look at post # 217 second pic down
Old 06-14-2010, 06:49 AM
  #226
john 67's Avatar
Just returned home after completing the 2010
hot rod power tour , 3,300 miles from New York to Iowa , to Mobile Ala. and back to N.Y. Car ran good all the way.John
Old 06-22-2010, 11:32 AM
  #227
C5_Pete's Avatar
Congrats!
This is a great thread and you have done a remarkable job building this car. It looks great.
Old 06-22-2010, 05:34 PM
  #228
john 67's Avatar
Thanks, I considered it a long road test , I brought a full set of tools and parts along not needing any of it. Plus there is plenty of help on the tour if needed.JOHN
Old 06-27-2010, 10:07 PM
  #229
68lsxc10's Avatar
I have followed this build thread before, but I just realized who you are. The flat black paint threw me off. I did not know this was the same car that got pulled over in Alabama!
PM me when you figure out who I am.
Old 08-09-2010, 07:54 PM
  #230
john 67's Avatar
Originally Posted by chree
When the collector gaskets blow out go ahead and choke up the $20 each for copper collector gaskets from S&P. I also used longer collector bolts and used two nuts per bolt. The collector bolts had a habit of loosening which of course blew out the collector gasket.
(My application is S&P shorty headers on an LT1, but the collector is the same.)
collector gaskets changed to copper !!
Old 08-14-2010, 07:17 PM
  #231
68lsxc10's Avatar
John, I just got the new issue of Hot Rod (October). There is a picture of your car on the autocross track in Birmingham. It is on page 58 in the top right corner. Just thought you might like to know.
Old 08-15-2010, 12:12 PM
  #232
john 67's Avatar
Yes I did see it , I came in 85th out of 85 cars , maybe I can improve my time for next year , are you guys thinking of going ? its a long time away but now is the time to start planning . JOHN
Old 08-15-2010, 09:52 PM
  #233
68lsxc10's Avatar
Oh yes! We will definately be there. I don't know if we will be able to make the whole thing, be we will do as much as we possible. We had a blast!
Chip is working on his Chevelle and my brother is now working on his 73 Z28. Both cars will have LS engines in them. I think that the power tour motivated them! If they are not ready, I guess we will be in my Chevy II again. (It maybe turbocharged by then).
We had a good time hanging out with you guys. We will have to catch up with you next year.
Your car is really nice. I know that when people see it, they don't suspect what is lurking under the hood. I had a pretty good idea after seeing it on the highway!
85th huh? Well at least you had fun. I would have liked to have run the autocross, but I threw the car together so fast to get it on the tour that I didn't want to push my luck.
Jay
Old 09-15-2010, 10:42 AM
  #234
lsjarhead's Avatar
excellent job, gonna be super nice, just wondering what oil pan your using
Thanks, Im doing a ls1 single turbo, 4L80E 66 chevelle
Old 09-15-2010, 07:45 PM
  #235
john 67's Avatar
It's an f body pan modified by Street & Performance, JOHN
Old 09-17-2010, 10:14 PM
  #236
john 67's Avatar
Got to go to the track today , got 5 passes in , ranged from 13.4 to 13.7
Old 09-18-2010, 09:25 AM
  #237
tonytone4143's Avatar
looks amazing! keep up the good work
Old 09-18-2010, 06:31 PM
  #238
90LS1TOY's Avatar
Default chevelle
x2 ^^
Old 01-04-2011, 12:28 PM
  #239
chevelledaddy's Avatar
Awsome build!!!!!!!
Old 02-10-2011, 09:10 PM
  #240
john 67's Avatar
Thanks for the compliment . the coupling is a hump hose coupling and a 45 by the air filter ordered from silicone intakes . com , I believe they are 4 inch but i'm not positive . I also made a bracket to support the setup near the filter , look in post # 181 for a pic.I made my my own brackets for the compressor, I did try the vint air stuff but it did not clear the chasis. and this system uses the main belt using the stock idler pulley.I can send you a set of templates for the brackets . there are kits that will mount the compressor high on the pass side if you dont mind it up higher. Pics of the brackets are somewhere in this thread.The interior grilles--I did not buy the kit I pieced it in here and there.they are from vint air , I think the side ones are an optional vent , I did not use the curved part of the bezel being that the area where they are mounted is mostly flat the center is theirs to a real pain to install being that there is nothing left of the dash strip when you are finished cutting it and it is real delicate at that point.AlsoI used their smaller diameter hose on ALL the outlets and either used their adaptors off the evaporator box and taped them in at the side vents - there was no enough room under the dash for the larger hoses.I am mostly pleased with the system,it is blowing cool but it seems to not keep up on really hot days, I need to go over the system and double check everything. What are you installing this in ? any pics ? JOHN
Quick Reply: Ls2-4l80e Chevelle **UPDATED WITH PICS**
