Ls2-4l80e Chevelle **UPDATED WITH PICS**
Old 02-10-2011, 09:13 PM
  #241
john 67's Avatar
P S pulley is stock for a 06 " Y" body ( corvette ) as well as the other pulleys
Old 02-10-2011, 10:19 PM
  #242
john 67's Avatar
I actually bolted it to the top of the cowl. If I remember correctly I used the front vint. air bracket ( the one closer to the firewall ) and attatched 1/4 "bolts to it so I could just attatch the nuts from the top of the cowl . on the other side I used some thin metal strapping from the unit to the cowl.I sealed them in the cowl to prevent water from dripping in.NICE install , I'll look for you on the power tour, JOHN
Old 02-10-2011, 10:23 PM
  #243
john 67's Avatar
Originally Posted by john 67
just starting some work on the dash.vintage air unit mounted and recieved 1 sport comp ll guage
pic of the front straps
Old 02-17-2011, 11:53 AM
  #244
devlmaycry's Avatar
Nice.
Old 06-03-2011, 05:53 PM
  #245
john 67's Avatar
Just started the 2011 Hot Rod Power tour . See you there, JOHN
Old 07-20-2011, 03:32 PM
  #246
FatfreeGTO's Avatar
John the car looks great, read your thread a few times now! I'm doing a 66 GTO with a LY6 4l80e swap.
Question about your gas tank and tanks inc setup. Did you use the stock tank, new stock tank, or spectra efi tank and swap out the pump? Not sure which route you went and this is my next hurdle to cross in getting information.
Thanks BJ
Old 07-20-2011, 09:04 PM
  #247
john 67's Avatar
I used a new tank for a 67 chevelle, I had to flatten it out to accomadate the tanks inc setup, about 8000 miles so far with no issues . JOHN
Old 07-20-2011, 09:16 PM
  #248
FatfreeGTO's Avatar
Nice, thanks for the info! Is the pump loud?
Old 09-15-2011, 09:44 PM
  #249
torataco's Avatar
Default nice pics,need advice
Im dropping an 99vette ls1 into a 67 lemans frame. Ordered an adapter plate and mount from hedmans. the plate and mount work on ls1 block, but the mount doesnt line up with the frames triangular, 3 bolt mount. The frame mount is too wide for the adapter mount. How did you set up your mounts?Is my understanding that the chevelle frame is same as gto/lemans, thx
Old 02-11-2012, 05:34 PM
  #250
tonyturbo42's Avatar
Hey John, About to start my LS3 TT in my 67' El - Camino project any updates? Would love to talk to you about some things. My email is Tony@vargasturbo.com or just throw me a PM. How much HP are you shooting for. Sorry if this was covered. The thread is 14 pages and I skimmed the best I could. I have most things worked about my fuel tank / Fuel system are still up in the air. Thanks in advance.
Tony
Old 05-03-2012, 09:15 PM
  #251
kanner1's Avatar
Love the build...very similar to mine. Chassis looks great. Wish I woulda pulled my body off building mine. Nice Car!!!
Old 05-04-2012, 05:19 AM
  #252
john 67's Avatar
Thanks , getting ready to do my third hot rod power tour with the car. JOHN
Old 12-01-2012, 06:03 PM
  #253
john 67's Avatar
Now that sandy has claimed all of my hard work on the car I hope to be totally disasembling it over the winter and starting over again.thinking of upping the horsepower a bit and using a 6l80e trans , I was pretty happy with the way the car came out but will be making some slight improvements . all ideas are welcome . JOHN
Old 03-17-2013, 11:04 PM
  #254
john 67's Avatar
A quick update . had car running, I have installed a 6l80e trans ( cut out tunnel ), harness so far is good , need to repin for 6l80e , changed computer,maf battery,alternator,starter, new flywheel and circle d 3000 stall conv . hoping to take it on the 2013 hot rod power tour.JOHN
Old 06-30-2013, 11:09 AM
  #255
Hart_Rod's Avatar
Any updates. Interested in how the A6 performed.
Old 06-30-2013, 08:36 PM
  #256
john 67's Avatar
yes, update. took car on 2013 HRPT to Texas and back. had issues with trans only due to a poorly located trans cooler . I installed a cooler with its own fan under car , didnt work out to well and installed one where it should have been in the first place(at hotel in Texas ), in front of the rad .Anyway trans performed well after that but I didnt beat on it too much as I was burning oil and engine wasnt running too well on trip back ,also I need to change my 3.73 to a 3.08 or a 2.90 . so I am happy but I need to do some tweaking with the car to get it where I want.JOHN
Old 06-30-2013, 08:44 PM
  #257
Hart_Rod's Avatar
Thanks for the update. Did you install a G8 shallow tranny pan? What about paddle shifters? Thanks for the info.
Old 09-23-2013, 06:54 PM
  #258
john 67's Avatar
I did install a g 8 pan . still hangs a bit low . should be ordering a shifter from speartech this week and installing .JOHN
Old 09-23-2013, 06:59 PM
  #259
kwhizz's Avatar
John.........Could you post a picture of your trans pan relative to the oil pan and bottom of the frame if possible.............I think the 6L90 is slightly lager????/.......
Thanks in advance!!!
Ken
Old 09-23-2013, 07:08 PM
  #260
john 67's Avatar
not up to pics right now( need camera ) but I can get a measurement tomorrow. I know my oil pan is even with the front crossmember .If i remember correctly the trans pan is 1 1/2 - 2 inches below frame leaving approx 4 " clearence .I remember cranking up the front coilovers for more ground clearence .I am pretty sure there is a difference between the 6l80 and the 6l90 pan - by the back corner I think JOHN
Quick Reply: Ls2-4l80e Chevelle **UPDATED WITH PICS**
