Ls2-4l80e Chevelle **UPDATED WITH PICS**
Old 08-04-2009, 07:09 PM
  #161
waynehartwig's Avatar
Sorry, can't tell in the pics, but where does your intake go?
Old 08-04-2009, 10:15 PM
  #162
john 67's Avatar
aaaaaaaa nowhere , trying to find an 05-06 gto air intake for now - not sure if it will fit cause the ps res. might be in the way so I dont want to spend to much on a performance one until I know it will fit.
Old 08-04-2009, 11:02 PM
  #163
john 67's Avatar
Modified the stock heater control to accept the vintage air controler.
Old 08-08-2009, 08:13 AM
  #164
john 67's Avatar
Old 09-01-2009, 12:06 AM
  #165
john 67's Avatar
Just a quick update - finished brake lines including emergency brake cables for the rear discs.had dash, rad support and a bunch of other parts powdercoated, had stainless exhaust done,greased everything that needs to be greased .hopefully I'll take it for a ride around the block this week. JOHN
Old 09-01-2009, 12:38 AM
  #166
RYU
RYU's Avatar
that things looks sweet!
Old 09-01-2009, 07:20 AM
  #167
robbied31's Avatar
John,
Everything looks great!!! I did the same exact thing with my vintage air controller you did just last weekend. Your dash looks much better than mine. I left the big chrome trim which limited the space for my guages. I missed that you started it up, congratulations. I am dying to start mine up.
Good Job man!!!
Please keep updating us
Rob
Old 09-02-2009, 05:49 PM
  #168
john 67's Avatar
A little more progress today - made a bracket for the ecm - mounted it in the center of the firewall up high , looks like there wont be any issues . had to secure it through the upper cowl as I did with the ac evaporator to prevent drilling through the firewall
now the fun begins
JOHN
Old 09-11-2009, 02:21 PM
  #169
banshee100hp's Avatar
Originally Posted by john 67
did you have this gauge holder / bracket made or is there a company that makes them...this is what i am looking for..nice looking project!
Old 09-11-2009, 03:32 PM
  #170
john 67's Avatar
I bought from a company called Haneline , about 200$ and then I had it powdercoated . the guages are a little tight where the guage bezels are on the top but it fits better than anything else I could find, its the best option without hacking the dash - if you used a covans plastic guage dash you would have to trim some of your dash by the column,JOHN
Old 09-16-2009, 04:30 PM
  #171
kevin 67/6.0's Avatar
Looks good how much was that setup. I have been thinking decota digital.
Old 09-16-2009, 05:56 PM
  #172
john 67's Avatar
it depends on what guages you use -- with the panel and the guages about 1000 $
Old 09-17-2009, 01:49 AM
  #173
Talking
[QUOTE=john 67;7829315]Tie rod oil pan clearance, transmission clearance & frame/engine mounts as of now...
Trans
haha you must ride jet skis...nice turf job!
Old 09-21-2009, 01:20 PM
  #174
At6texan's Avatar
cool build
Old 10-01-2009, 06:07 PM
  #175
parkst's Avatar
Default ac compressor bracket
i was wondering if i could get a template of the ac bracket on your engine
Old 10-03-2009, 07:10 AM
  #176
john 67's Avatar
Just p m me a mailing adress and I"ll send you a set
Old 10-08-2009, 09:44 PM
  #177
john 67's Avatar
A quick update, ordered an intake system for an 06 gto and had to slightly modify - lengthened the coupling off the throttle body and added a 45' just before the air filter, still need to make a bracret to support the assembly by the air cleaner. cut the vintage air grills into the dash and ran most of the ductwork, cut some holes for the heater and ac hoses to keep them hidden in the fender also did most of the wiring and neatening up , installed tilt column, installed a new B&M shifter cable , installed condensor and got all brakes wworking including the emergency brake
Old 10-10-2009, 08:29 AM
  #178
looking good hope to start my ventage air soon
Old 10-11-2009, 08:26 PM
  #179
john 67's Avatar
Buttoned a bunch of stuff today and TOOK CAR OUT FOR A RIDE ! feels nice after about 4 years or so , great power , got on it a littlt bit , still need to do an alignment ,put doors back on and windshield , but for 2 times around the block everything seemed o k ,JOHN
Old 10-11-2009, 08:49 PM
  #180
westxwitesnake05's Avatar
great job man, looks amazing!
Quick Reply: Ls2-4l80e Chevelle **UPDATED WITH PICS**
