Has anyone made a LSX work with a 153 tooth Flywheel?
I assume the major issue would be selecting a different starter, and customizing the mounting to get the starter gear closer to the crankshaft centerline?
McLeod is working on the needed adpater/block that allows the mini starters (Hitachi models) to mount with a 153 tooth flywheel/flexplate. Give them a call, the project should be done by now.
You will need to grind off a small portion of the block, that was used during the factory assembly proceedure, but not needed otherwise.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by Whistler
I would assume another problem would be torque converter bolt access. There's already nexto to no room with the big flywheel.
Originally Posted by ChevyFanatic
I'm looking at this for manual trans applications, where the truck sized LS1 flywheel is too big to fit in the bellhousing (such as that of a ZF 6speed corvette transmission)
Andrew
Originally Posted by mattmartindrift
price
Andrew
