What computer is for a 24x LS2 engine?
Old Apr 12, 2007 | 04:07 PM
Steve1969LS1's Avatar
Default What computer is for a 24x LS2 engine?
Is it the E40?
As I recall the E38 was for the 58x engines and the E40 was for the 24x like in the 2005 Vette.
Anyone know the GM part number? Also, I need to buy one asap. Any leads? (the dealer was no help)
Thanks!
Old Apr 12, 2007 | 04:29 PM
slow's Avatar
The pcm out of my late 2006 GTO has the following info on the label.
12604791 YMUM
Delphi automotive systems
Barcode:
Service number: 12596679
5349
The service number comes up on some of the GM direct parts websites for around $280
I hope this helps.
Ryan
Old Apr 12, 2007 | 04:34 PM
12604791 YMUM
Barcode:
5349
I hope this helps.
Ryan
But isn't that a 58x reluctor LS2? If so then it's the E38. I'm also not sure if the plug is the same for the fly by wire deal.
Here's a pic of it. Like I said, I'm unsure what other vehicals it's found in but I know it was in the '05 LS2 Vettes.
Old Apr 12, 2007 | 04:48 PM
Brains's Avatar
You could always pick up the cheap n' plentiful 99+ F-car PCM. It works with the 24x wheel obviously.
Old Apr 12, 2007 | 05:04 PM
But not with my fly-by-wire throttle body
Old Apr 12, 2007 | 05:50 PM
Jones'n's Avatar
The older LS1 PCM will still work with the Fly by wire throttle body. You would need a TAC module and pedal from the older car/trucks.
As for the '06 GTO box, it is an E40. The GTO's never came with a 58x LS2, not even the '06.
Old Apr 12, 2007 | 08:37 PM
Brains's Avatar
Exactly what Jones'n said
Old Apr 12, 2007 | 08:58 PM
Well, I really don't want to redesign the whole car.. lol
Installing a diff pedal assembly would be a royal PITA. Good to know about the GTOs though, thank!
I found a contact at GM that had a couple "laying around".. they're on the way.
Will be nice to have a spare all programmed up and ready to go
