89Notch 5.3/T76 turbo/th400 etc Build Thread.
Old 09-15-2008, 01:30 PM
  #141
tirefryin_s10's Avatar
No still rocking the air bags for now until winter.
Old 09-15-2008, 01:44 PM
  #142
97'-lt1's Avatar
Well then an anti-roll bar will help alot..Next on my list of suspension is a-arms and coil overs, plus some adjustable uppers..Then I should be set..But I could tell a big difference in how the car leaves with the anti-roll bar...Kind of like a night and day difference..
Old 09-16-2008, 01:45 AM
  #143
Slow5.0.'s Avatar
Im glad these motors are holding together!
Old 09-16-2008, 09:04 AM
  #144
dman's Avatar
how much air do you run in them? I ran a bag just on the pass side in my turbo buick, it had an open rear and wouldn't hook for **** on anything less than 20psi in the bag. eventually the pressure ruptured it. the bag was good for 1.56 60'
Old 09-16-2008, 11:17 AM
  #145
I generally run about 10 psi In it , the manufacturer recomends no more then 35psi
Old 09-16-2008, 12:24 PM
  #146
Crowder's Avatar
there strong as hell, just imagine with forged internals.
Old 09-16-2008, 12:28 PM
  #147
dman's Avatar
for some reason anything less than 20 psi showed no improvement in 60' on my car. does the car twist when it launches?
BTW, how did you know your 5.3 was a 5.3? is there any external signs? the reason i ask is because a buddy is looking at one, it just says 4.8 / 5.3 on the block
Old 09-16-2008, 12:47 PM
  #148
Cylinder head casting # ..... My car did twist really bad but seems to be alot straighter with the air bag now.
Old 09-16-2008, 06:35 PM
  #149
Slow5.0.'s Avatar
how much hp would you say your pushing around 14psi? How much more power do you think you could pick up using a 6.0 with the same modifications?
Old 09-16-2008, 07:57 PM
  #150
overkill-lt1's Avatar
awwwwwwwwwww that would look soooooo much better in an rx7
Old 09-16-2008, 07:58 PM
  #151
Crowder's Avatar
look right below the driver side head it will say 4.8/5.3 sear my for sale thread i have pic posted up. I think the heads are different, also i think the vin can tell also. I have a 5.3 ready for boost for sale sorry for the
Old 09-16-2008, 08:34 PM
  #152
On 8 psi it made 450rwhp
on 11psi it made 510rwhp
SO on 14 I would guess 550ISH
and on 16.5 all the calculators put it right around 650-660 rwhp . I guess I could put it back on the rollers seeing as how I own a dyno LOL
Old 09-16-2008, 10:36 PM
  #153
Slow5.0.'s Avatar
Yea that would be cool. I am just wondering what I will put down with a 6.0/ls6 cam 70mm around 10 psi or so.. Im still undecided weather or not to use meth.
What plugs do you run btw?
Old 09-17-2008, 10:59 AM
  #154
Should be over 500 rwhp for sure .... I run a lot of meth, and as for plugs I run the TR6 Gapped at .28
Old 09-17-2008, 01:04 PM
  #155
dman's Avatar
meth is your friend!!!!
Old 09-17-2008, 07:39 PM
  #156
Slow5.0.'s Avatar
I made 500whp with this same turbo and 10 psi on a mild 5.0 litre (280whp). By the loooks of this engine.. I would hope for more then 5 we'll just have to see.
Old 09-18-2008, 11:59 AM
  #157
LOL It would probably make 550 ish on 10psi depending on intake etc.
Old 09-20-2008, 11:31 AM
  #158
Well after going up a bit in tire size and changing a few things on the suspension the old heap of **** pickup truck motor finally did it 9.99@140 the car made 5 passes over 140 mph and it was all on 14.5psi and straight pump 94 with meth. The car finally left good with a 1.48 60 foot. Overall a great night of racing ran new personal best et,60 foot and mph and did it all on my street set up with the boost down and pump gas !!!
Old 09-20-2008, 11:35 AM
  #159
single digit dreamer
parish8's Avatar
nice runs. congrats. you going to keep turning it up or just enjoy it for awhile.
Old 09-20-2008, 11:46 AM
  #160
Year is almost over it is getting 18 psi and some good fuel for next time out!!!! LOL
Quick Reply: 89Notch 5.3/T76 turbo/th400 etc Build Thread.
