Ls1/Ls6 engine swap motor mounts 55.99!
From what i have seen...most people are charging $100+ for mtor mounts.
well i've just ordered mine from Jegs for $55.99 for my G-body el camino. These mounts can be used on any car that originally had a older model sbc.
Part #969-4592
Part #969-4592
They are easy to make and can be taylored to what you need in either of the two common styles of plates (S&P or BRP). You can move the position of the mounts and use different thickness to move the engine around as needed.
I made mine from 1/4" steel and only used common tools, 4" Grinder w/cutting wheels, file, drill and taps. I then powder coated them. You can use any type of mounter mount.
Part #969-4592
Part #969-4592
might they work in a 3rd gen camaro?
equipped with a sbc/tpi?
I just ordered a set. I'll let you know about quality when they arrive. I was surprised when placing the order that Jegs has "Free" shipping. When I went to check out, they added a $12 "Handling" charge. I guess they get you one way or another....gp
Location: Way Out In The Boonies Chasin' Hill Billies, North GA
Originally Posted by pist0lpete
I made them myself with some scrap steel and paid like $10 for bolts. Thats a tough deal to beat right there and its super easy.
Thanks Deeloc for the heads up - I'm about to order a set
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by 5150mechanic
These are the transdapt mounts, right? They sell them with a 1" set back too, w/ or w/o rubber pads.
You can get them at Summit also! They're only 53.69 at Summit, plus summit only changes 10.95 for handling... Save a little bit of cash...
Summit part number TRD-4592
or just click below.
http://store.summitracing.com/partde...5&autoview=sku
