BUILT LSX Stroker into a 95 Z28
#141
So let me get this straight, well the LS1 k member bolt right up to my 95 Firebird? Well it work with the suspension that's currently on it? Well my 95 4l60e bolt onto the ls1 or does it need something to work right. And well the lt1 AC bolt onto the ls1? Sorry for the newb questions.
On a side note what would take for you "Merv" to fab up a wiring harness.
#142
The LS1 K-member will bolt directly up, just make sure you use the LS1 Steering Rack aswell.
I recommend getting a 1998 and up 4L60E Tranny, the Wiring in anything 1997 and back isn't compatible. I don't know about the AC, I never ran it.
PM sent about the Wiring..
#147
what exactly did you do? My abs is broke and I'm ripping out the AIR and while I'm at it want to ditch the abs while I'm at it but dont want to spend the money on some thing like a SLP kit
nice swap by the way
my 383 LT1(please dont be hatin cause the LTx) will be goin in soon and I think it will give you a run for your money
#149
That Moser is a nice piece..
#150
i went to the junk yard and took that proportioning block and the lines from an '89 camaro, then i used a flare tool and made it adapt into my car. It was about an hour of work, but it works very well. I have about $5 invested.
I'm not hatin on the ltx stuff..lol..i just wanted something that had alot more aftermarket.
just didnt want to get a big BOO LT1 BOO
#157
What you want to know?
#158
nothing special on the brakes just connect the factory lines to the non abs block? right
fronts to the front output rears to rear output do you have to retain any of the old abs unit?
I just want to make sure of everything be for I cut the brakes lol
thanks for your help merv
