putting ls1 in a 85 c10
What else do I need? Also, has anyone else done this?
Good Luck
It came with LS1 mounts built on. What kind of tranny are you going to run? Do you already have the LS1?
This is an awesome swap by the way! Tons of room to work under the hood!
Its no big deal. As far as your crossmember, just move it where you need it. Put your motor mounts where you want them, and bolt the trans member where ever it falls. Good luck.
