The G-Body Swap Thread
As for the hotwire harness, I'm probably blind but where is it on the site?
Lastly, for those who say to swap to a GM v6 PS pump pulley, do I do any v6 pulley? I'd like to get that pulley purchased as well so I can start this mock up process next month!
heater box notch
relocated alt with speedway motors kit not totally satisfied with it yet though.... heard a truck alt will work better...
ill probably take my heater box out as well so clearance on that wont be an issue
as for your motor mounts what trans you using?
I think every gbody is different...
heater box notch
I have the normal ones and everything fit in perfect..even the Headers.
The Round Coils have better clearance tho..I have the same Heat-only HVAC box.
Here's the best pic I have of the front where the Alternator is in the stock location..
I am ready to get my car back out. It's got a 98' inspection sticker on it. Putting a turbo 6.0 with 4L80 into it. Thinking Speedtech headers? Or Virgina speed? with a 74mm turbo. TBSS intake I have sitting around and maybe a 215cc TFS head and custom cam.
I have a few sets of the truck accessories which seem to work correct..
I would like to use the 6.0 truck pan if possible, but the car sits on the ground and should be pulling nice wheelies on the street with my set up...
Is there a engine mount that makes use of the 6.0 truck pan nicely? Or should a pony up for a CTS-V pan? What year CTS-V? or hummer or the others that are on here. Get's confusing!
Thanks, I tried searching. I am just a lost soul and need guidance
My car
Modify the truck pan, or CTS-V pan with 1in setback plates or Fbody pan with same plates. Fbody clears barely but I would notch a little for piece of mind.
