The G-Body Swap Thread
JON
PSI
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Jon
PSI
Ebay Store
[Engine is turbo'd, so I have no need for a notch on the dr side.]
I have also removed the rubber insulators at the frame ends. They are replaced w/ steel bolt down plates.
Someone asking about truck/Hummer pans.. Here's a comparo of an H2 pan and a H3, [LH8, aka "muscle car" pan]
New is the H3.
I made my mounts, and had to notch the ft x to clear the H2 pan. This kept the engine low in the frame, and it's as far back as practical. [A ft mt turbo app.]
I'll likely have to shorten the pan, as it's way too far below the x for "comfort".
I will add that others have done just the tach resolution setting with a pull-upn resistor and have not built the circuit I used in addition to the proper resolution setting and have had no problems.
Regards,
Matt
https://ls1tech.com/forums/conversio...og-guages.html
1.I have a 84 monte ss that came from the factory with a 3 speed. I have a 4l60e form a 2004 2 wheel drive truck and I'm using a harness from a 2000 f-body. I need to know what you guys are doing about the neutral safety switch? How should I go about setting this up?
2. I would like to fuse the OBD2 port what wires should I use to do that?
Thanks
If you have the PRNDLE Switch on that 4L60E I would incorporate that into the Wiring Harness..then Tune it..it's easy.
