The G-Body Swap Thread
Old Oct 22, 2019 | 01:44 AM
  #1821
witman69's Avatar
Default Supercharger reservoir for gbody pics?
Hi guys: I have most of the parts needed for adding the lsa to my LQ4. Ill probably be in the 600hp range, and visit the track a couple times a year. Im debating on intercooler reservoirs. What are you guys using? Br Jerry.
Old Oct 22, 2019 | 07:31 AM
  #1822
Houston_t's Avatar
My plans are to start with a factory unit and upgrade from there if needed, my car will be more of a street/cruiser and i doubt i will ever hit the track more than once to see what it will do. Seems like Afco is a go to unit for the camaro guys, guess you just go with the biggest one you can squeeze in there.
Old Oct 22, 2019 | 10:18 PM
  #1823
witman69's Avatar
I have the Afco Intercooler already. More concerned about the reservoir actually. See the last 3 pics.
Afco Inet/Return
It fits, Barely....
Canton
Canton
Ebay
Old Oct 23, 2019 | 07:03 AM
  #1824
Houston_t's Avatar
Oh sorry i just now saw that you said the tank. Here is one in a cutlass mounted on the pass side inner fender, its meant to mount in the battery box.
https://www.amazon.com/CXRacing-Supercharger-Aluminum-96-04-Mustang/dp/B00EPYK6T2/ref=sr_1_3?keywords=CXRacing+Aluminum+Supercharger+Coolant+Tank&linkCode=sl2&linkId=1bfdf5a55d419e4fd1e54616138d4499&qid=1571831481&sr=8-3 https://www.amazon.com/CXRacing-Supercharger-Aluminum-96-04-Mustang/dp/B00EPYK6T2/ref=sr_1_3?keywords=CXRacing+Aluminum+Supercharger+Coolant+Tank&linkCode=sl2&linkId=1bfdf5a55d419e4fd1e54616138d4499&qid=1571831481&sr=8-3
Old Oct 25, 2019 | 07:12 AM
  #1825
Houston_t's Avatar
Whats the part # for the intercooler you are using ?
Old Oct 27, 2019 | 08:27 PM
  #1826
the_merv's Avatar
Veteran: Air Force
Tons of info here...
https://ls1tech.com/forums/conversio...t56-build.html
Old Oct 28, 2019 | 06:50 AM
  #1827
witman69's Avatar
Thanks for the good info guys! My intercooler is the same Fbody Afco most folks use; part # 80283NDP
Old Apr 18, 2020 | 10:15 PM
  #1828
Brian.DSP's Avatar
About to start a LY6 with a LSA supercharger swap in my 87 Grand National. The block did not come with any accessories so i have to buy a kit or piece it together, what would be the best FEAD setup to run and use a low mount ac compressor ?
lsx concepts has a really good kit with a nice blower belt drive
Old Apr 18, 2020 | 10:19 PM
  #1829
Project GatTagO's Avatar
Unless they changed it, I recall that setup not having enough wrap on the blower pulley.
Andrew
Old Apr 19, 2020 | 01:33 PM
  #1830
Brian.DSP's Avatar
Andrew
They have two different drive one is only intended to be used with stock pulleys,which I think is enough wrap for that.
the other is a "race drive" which seems to have plenty of wrap.
I can't say whether or not they changed the drive as this is the only one have seen from them.
I don't like the other drive that share a belt with all the accessories.For my power goals I think the race drive will be up to the task.
Old Apr 29, 2020 | 12:38 AM
  #1831
cashbyz28's Avatar
Default 1981 elcamino 5.3 swap help
Decided to take the stock 5.0 and TH350 out the 1981 elcamino i picked up a 5.3l engine and tranny from a 2003 tahoe i have some questions reguarding the swap i have a run down on parts list i ordered the engine harness from swap specialities and performance, ordered the sliding engine mounts from dirty dingo, ordered the corvette fuel pressure regualtor filter combo, ordered the 1986 elcamino tbi fuel sending unit and a fuel pump from summit racing, i have an aluminum radiatior , my questions are i have an aluminum radiatior thats made equipped for the car itself but not made for the 5.3 ls is that going to be an issue when installing tranny lines ect? My next question will a mechanical equipped fan that is on the 5.3 work and have enough clearance? I have the stock driveline that came with the elcamino will that work on the 4l60e? Will the 5 3 stock oil pan have enough clearance being that i dont have any suspension upgrades or lowering kit? I would appreciate and help i can get.
Old Apr 29, 2020 | 07:44 AM
  #1832
dlwilson's Avatar
I initially used the GMPP pan on my 1979 El Camino, but the sump hung down below the crossmember. I switched to the Holley pan, and that solved the problem.
Old Apr 29, 2020 | 07:58 AM
  #1833
He should also use the Holley mounts, since they are designed to work with the pan.
Andrew
Old Apr 29, 2020 | 02:57 PM
  #1834
dlwilson's Avatar
I should have said that I am using Metaltek mounts.
Old May 6, 2020 | 02:10 AM
  #1835
witman69's Avatar
My 6.0 engine was from a 02 Escalade, (in an 86 monteSS)so similar setup as yours. The truck pan should go, or you will regret it. I used a CTSV oil pan, but would do the Holley Pan if I had to do it over. I used the holley kit, Engine mounts, tranny mount, headers, etc. Works great. Got a new driveshaft from PST. The old one was meant for a 165hp. 5.0 carbed engine. I have never seen a mechanical fan in an LS swap, most guys grab a Fbody radiator and electric fans. I measured mine, and there is 10.25 inches between the Harmonic balancer and Radiator, so If you can find a way to route the Radiator hoses, give it a shot. The tranny lines are on the passenger side, so that should not be an issue. However, if you are running AC, my original Gbody Radiator setup had a Driver side AC connection. You may want to consider replacing the original fuel tank as well. They can get pretty nasty after 30 years. BR Jerry
Old Jun 15, 2025 | 12:34 AM
  #1836
Nick_R_23's Avatar
Alright, I’m still reading through this entire thread, so I’ll probably answer some of my own questions, but what’s the cheapest way to drop an LS into a G-body, currently? I have a 1985 Old Cutlass with an Olds 307/200-4R. I’d like to keep/reuse as much as possible, even down to the factory exhaust. Plans would be a carb’d 4.8 or 5.3, nothing fancy. Yes, I know Holley parts exist, but $3500 for one of their packages doesn’t work in my current budget.
Motor mounts and crossmember? Seems like some people used the Carshop style with SBC frame mounts. I’d like to keep the stock 200-4R and driveshaft if possible.
Oil pan? Seems like the CTS-V pan is the ticket.
Stock manifolds/y-pipes (preferably) or headers?
Do truck accessories clear?
Mating the 200-4R kick down cable to an carb LS intake or LS throttle body if I decide to keep injection?
Bolting an LS to a 200-4R take anything special?
