The G-Body Swap Thread
Old Jan 30, 2018 | 04:30 PM
  #1781
slowlsx's Avatar
Anyone interested in a turbo kit for a g body shoot me a PM!! Will let it go cheap!
Old Jan 30, 2018 | 09:47 PM
  #1782
onebadbowtie86's Avatar
I wish! Bad *** car!
Old Feb 3, 2018 | 08:10 PM
  #1783
HighLiner's Avatar
[QUOTE=slowlsx;19822419]Anyone interested in a turbo kit for a g body shoot me a PM!! Will let it go cheap!
Pics?
Old Feb 5, 2018 | 08:39 PM
  #1784
Originally Posted by samckitt
I have Corvette accessories, in an 86 Monte & using the factory Vette high pressure line. I do't remember what year the hose was from, pump is a C5, all had correct fittings.
Do you have any pics of your power steering line hooked up? Did you have to bend the line or anything?
Old Feb 14, 2018 | 10:26 PM
  #1785
HighLiner's Avatar
Since the 98-02 F body headers use to be the go to headers for swaps has anybody tried the mid length versions?
Old Mar 19, 2018 | 08:31 AM
  #1786
ZEN357's Avatar
Why don't you just convert over to a hydraulic setup?
Old May 16, 2018 | 03:36 PM
  #1787
HighLiner's Avatar
Well, I pick up a set of LS3 crate engine manifolds and they don’t clear the frame so back to the drawing board
Old Jun 6, 2018 | 09:19 PM
  #1788
nawlins-tim's Avatar
Originally Posted by BLWN1
ARH makes g body and I can get them a little cheaper possibly
I would love some reviews of the ARH gbody headers. Good quality , I kno. But Not many gbody guys use them.
Old Jun 29, 2018 | 09:49 AM
  #1789
Elcodude85's Avatar
Default what water neck and thermostat to use for 04 5.3L??
Does anyone know what water neck to use on their 5.3? doing a turbo ls swap in my el camino and cant seem to find the right water neck and 160 degree thermostat for a mechanical water pump
Old Jun 29, 2018 | 10:44 AM
  #1790
WSLN 6's Avatar
I used a billet straight outlet, seems to work fine. Not at my car, don't remember the brand lol
Old Jun 29, 2018 | 04:24 PM
  #1791
jmd's Avatar
jmd
Vette or Camaro? With which engine Mounts?
Old Jun 30, 2018 | 11:34 AM
  #1792
Project GatTagO's Avatar
Does anyone know the wheel and tire package on the Chevrolet Performance Monte Carlo?
Andrew
Old Jun 30, 2018 | 11:38 AM
  #1793
Originally Posted by onebadbowtie86
Looks like a solid car. They are getting very hard to find up here in the rust belt. I'd say his asking price is fair/good for my area.
This car is extremely clean and tempting me to go get it:
https://nmi.craigslist.org/cto/6092610755.html
Originally Posted by z71yacht
That's a very good looking example. It always drove me nuts how the SS on the horn button always seemed a little crooked when compared to the raised horn logo. Typical rust spots are the trunk, wheel wells, drain tracks, frame and the roof just above the drivers door. That's a factory 305 for sure! LOL. Take good care of that one!
Just to close the loop on my earlier post. I did not buy the car, but my friend Brian did. He ended up paying $5k. He flew down from Chicago and the next morning we headed to north Alabama and got the car. We installed new sway bar endlinks in the past owners driveway and then Brian drove the car home to Chicago. He averaged about 75mph and got over 20mpg.
He is super happy and is collecting parts for his build. Sadly it will not be a LS swap, but it will have over 1000hp!
Andrew
Old Feb 18, 2019 | 12:17 PM
  #1794
TDMKR496's Avatar
I'm having issues with my 12643HRK mounts, it seems as if the mounting holes on the engine mounts are wider than the mounts on the frame. Has anyone had this issue?
Old Feb 18, 2019 | 12:55 PM
  #1795
user 4737373's Avatar
Are you using 2292 mounts? Post up some pics of your engine brackets so I can confirm they are correct.
Old Feb 18, 2019 | 01:28 PM
  #1796
TDMKR496's Avatar
Yes, I have tried two sets and still have the same issue. I read through the instructions several times and noticed it states "For use with vehicles originally equipped with a SBC engine" But my frame has the same hole pattern as the instructions. Not sure if that makes a difference..
I called Holley Tech this AM and they are looking into it.
Old Feb 18, 2019 | 02:12 PM
  #1797
They will probably send me an email to my desk for assistance and I’m at home today. If you post a couple of pics here I can probably help you get it figured out faster than waiting for me to return to work tomorrow.
Old Feb 18, 2019 | 02:41 PM
  #1798
TDMKR496's Avatar
Thank you sir! The picture with the bolts in the clam shell mount is the pass side, and the drivers side holes are over a diameter away from being able to get a bolt in. Can you give me what the dimension between the two holes in the clam shell mounts are supposed to be?
I appreciate you helping on your day off!
Old Feb 18, 2019 | 02:45 PM
  #1799
TDMKR496's Avatar
Also, can you give me the dimension from the back of the plate to the center of the locating hole?
Old Feb 18, 2019 | 04:36 PM
  #1800
What brand of poly motor mount inserts are you using? I don’t reconize that grey color. I have no way to give you the dimension you are asking for from where I sit today.
