The G-Body Swap Thread
Gbody tank and Bbody tanks are way different in size and filler neck location. Gbody filler neck is off set.
I would have just purchased a 94-96 Impala ss fuel tank, sending unit and pump for your caprice swap. Tank is a direct swap over. Or any 90's bubble efi fuel tank for that matter. Should even be able to get fuel lines from a Bubble caprice/impala or roadmaster since they share same frame too so you can put those on your box caprice.
Also need to place order for some braided fuel lines.
and what brakelines will fit with the c5 corvette LS1 steering pump and the monte steering box?
Place it in the back and you got two short lines from tank to regulator, then just one long feed line to rails.
Not sure what pros/cons are of placing it in either place though besides the $$ on fuel lines.
Placed order for sending unit with pump and harness kit from racetronix
Purchased Fuel filter/Regulator
Purchased 98-02 LT pacesetter headers from amazon (cheapest place I could find with free shipping)
Purchased Carshopinc 1in setback plates
Still need 2004+ truck intake fuel rails (returnless rails)
Fuel lines
Fittings
to tie up the fuel system
Anyone have a CTS-V oil pan for sale?
About to go double check my radiator measurements and order a double pass radiator.
Opening up the block and discovered this so called rebuilt block, has never been rebuilt.
Cleanest thing on this motor were the heads and new head gaskets, rest of the engine looks like it has well over 90-100k.
Don't know what to do right now. Placed orders for a lot of parts past few days, so pissed might have to hold off on this swap now if me and this salvaged yard can't come to an agreement on this situation.
https://ls1tech.com/forums/generatio...ting-6-0l.html
To run factory speed/Rpm gauge you need some B.S. that cost like $400 correct?
Then depending on which Auto Meter guages your taste buds quench for that's $400-$700 for all the main gauges you need- Fuel/Volts/Temp/Oil/Speed/RPM. Which should all be the electric gauges.
Then you got Dakota Digital. Right now they have two options for Gbody.
There first gauge cluster.
Now they also offer this one.
What is everyone doing? Can you post up pics if possible.
If I go with Auto Meter I'm trying to work up some nice ideas to incorporate turn signals, high beam, gear shift indicator to make it look somewhat custom/still factory looking then the normal slapped in gauges with two light in there for turn signal. Ya know that somewhat street car/track car look.
Dirte
