The G-Body Swap Thread
Old Mar 9, 2016 | 01:16 AM
  #1581
G-BODY-JAMES's Avatar
Originally Posted by black02-z28
did find some really good pics here, will compare to what I did. Looks pretty close:
http://hotrodregal.com/brp-hot-rods-...il-pan-part-1/
B-Body??? Did u mean g-body?? An 80 elcamino is a g body correct??
Old Mar 9, 2016 | 10:26 AM
  #1582
upflying's Avatar
Yes, the '80 El Camino is a G body but I think GM was still calling them an A body at that time. The designation of G body did not occur until '81.
Old Mar 9, 2016 | 06:10 PM
  #1583
jimmyg's Avatar
I am trying to use the MuscleRods B-body mounts to put a 2000 LS1 with the LH8 pan into a 1980 El Camino. The block side mounts are clearly labeled which way up. Trying all sorts of ways on the K-member mount, but no matter what I do can not get it to line up. The best I have gotten is the mounts seem about an inch too far out line up. Here are some shots of the closest I have been. Seems most I can find are people using the 1" setback with SBC mounts, no good photos of how these go in. Anyone have any ideas?
http://www.brphotrods.com/products/7...cts/index.html
Should've used the hooker mounts would have slid right in
Old Mar 9, 2016 | 07:51 PM
  #1584
upflying's Avatar
Holes in the ac box too. I put my engine in using hooker mounts and removed the right valve cover and coil packs. No damage to ac box.
Old Mar 9, 2016 | 10:52 PM
  #1585
Camaro1-5fan21's Avatar
considering doing a grand prix g-body with an lsa and a tr-6060.
Old Mar 10, 2016 | 08:58 AM
  #1586
jimmyg's Avatar
Ya I realized that after the fact lol . I was one of the first to use these mounts.the thing I love about this system is even with poly inserts,my car is vibration free. I removed the nose and put motor/tranny in in one shot. Took about 45 min.
Old Mar 14, 2016 | 10:21 AM
  #1587
black02-z28's Avatar
Thanks all, got it bolted in! We actually put some holes in the box pulling the 305 out, will have to clean it up. I do think if I do it again, will use the one 1" setbacks with SBC mounts.
Old Mar 14, 2016 | 05:28 PM
  #1588
rayfrausto's Avatar
Default Crossmemeber
Hi guys anyone use a summit crossmember before. I'm ready to order mine and drop the motor in and I think I want to order the summit 4l80e crossmember for g body cars. I'm using 1 inch set back plates stock clamshell mounts. Summit part number is SUM-770324
Old Mar 15, 2016 | 10:10 AM
  #1589
parts are here the holley 5.75 inch PS pulley looks to be mint!! stay tuned!!
Old Mar 16, 2016 | 12:07 PM
  #1590
Old Mar 19, 2016 | 01:10 AM
  #1591
she fired up and all seems good
Old Mar 20, 2016 | 06:44 PM
  #1592
L92 OLDS's Avatar
Video please
Old Mar 20, 2016 | 08:06 PM
  #1593
Old Mar 20, 2016 | 08:20 PM
  #1594
jimmyg's Avatar
Things gonna rip !I'm digging the afco heat exchanger ,I think im going with that one too. Great job getting running
Old Mar 20, 2016 | 11:31 PM
  #1595
Ya the afco one is meant for it in size the only thing I diddnt like was the in/out locations on it but it's meant for a f-150 so.. Guy coulda welded em in better spots if so desired but I had heater hose with pre bent 90's in em and made it all work
Old Mar 22, 2016 | 05:45 PM
  #1596
upflying's Avatar
If anyone needs a DBW solution, I managed to install this Corvette pedal in my '86 Monte Carlo SS.
Old Mar 23, 2016 | 11:30 AM
  #1597
bigmandengo's Avatar
Looks good! Do you have a part number or year of Corvette?
Old Mar 23, 2016 | 12:28 PM
  #1598
redss86's Avatar
What kind of bracket did you use to mount it? Custom made on, or bought one?
Old Mar 23, 2016 | 06:42 PM
  #1599
upflying's Avatar
The pedal is attached to the DBW unit which is attached to a bracket to the firewall. I did angle the DBW unit on the stock bracket..
Both the bracket and the DBW came in a kit from GMPP.
GM part #10379038
Jegs has them..
http://www.jegs.com/i/Chevrolet-Perf...79038/10002/-1
Old Mar 26, 2016 | 12:49 AM
  #1600
pretty much got the column shift linkage figured out now!!! th350 trans with the hooker/holley LS swap stuff
