The G-Body Swap Thread
Old Feb 14, 2016 | 10:34 PM
  #1561
G-BODY-JAMES's Avatar
Originally Posted by 1970camaroRS
Yes, you can just do that. You can also remove the spouts and tap the holes and install pipe plugs. Someone's going to tell me you can't do that...don't listen to them.
oh ok perfect ill just run the hose
but out of curiosity wouldnt plugging those holes cause issues? or have you done this already haha???
Old Feb 15, 2016 | 05:27 PM
  #1562
dynodanmanda79's Avatar
What transmission crossmember are you guys using with the 1"setback mounts and a 4l60e? I bought thr Jegs 700r4 crossmember thinking it might work and it ended up being 2" too far forward
Old Feb 15, 2016 | 09:56 PM
  #1563
Originally Posted by dynodanmanda79
What transmission crossmember are you guys using with the 1"setback mounts? I bought thr Jegs 700r4 crossmember thinking it might work and it ended up being 2" too far forward
with the hooker motor mounts i used the stock crossmember with the th350 trans
i bought the hooker/holley ls swap crossmember (works with th400 and other transmissions too, with specific install kit sold seperatly) as i am eventually going to a th400
Old Feb 17, 2016 | 02:11 PM
  #1564
all parts ordered,(except serpentine belt) should fire her up next days off (3 weeks)
QUESTION--- to get the proper length belt now that pulley sizes have changed etc how do i go about that the best way? ive read using a string on the proper belt path and measuring it after to determine length but anyone have any input to this??????
Old Feb 17, 2016 | 04:25 PM
  #1565
jimmyg's Avatar
Originally Posted by G-BODY-JAMES
i found out the wires from the supercharger go to the MAF sensor just get tied in. i think i found a good pre made heater core loop hose for the heater core delete, lower rad hose part number gates 21059 trimmed 6 inches works mint!!!!
QUESTION what air to liquid intercooler do you guys know of or recommend the stock magnusson one for 2010 camaro was 23x15x2-1/4 inches dimensions and that blower always got heat soaked so i want bigger as i have way more room now. i looked and looked best i could find was this one for a ford f-150 by AFCO its 26x15x5 inches part #80284NDP about $500
or a custom one by bell intercoolers but man they aren't cheap!!!
Silicone intakes.com has one for 179$ 26x7x3.5
Old Feb 18, 2016 | 10:35 AM
  #1566
sounds decent and very cheap price>... although mine is on order its a little thicker and is a dual pass intercooler/heat exchanger so thats a bonus. little more quality for the cash
Old Feb 18, 2016 | 07:38 PM
  #1567
jimmyg's Avatar
How big is your reservoir? Guy at whipple told me I needed a 2 Gallon. I guess the more coolant you have, the better
Old Feb 19, 2016 | 10:32 AM
  #1568
the reservoir for the maggie kit is so small my guess is 1-2 liters max, that is another thing i wanna change at some point but the large heat exchanger (intercooler)is going to help. eventually ill get a custom tank made a bit bigger. magnuson did a nice kit for the camaro as they keep everything fitted nicely under the hood but way too small of capacity, got the room now and im going to use it
Old Feb 24, 2016 | 05:58 AM
  #1569
z71yacht's Avatar
What would ya'll recommend for a ford 9in donor? I'm told there's a few years the mustang had a usable rear end for the g body, but I cant find any clarification. Obviously it would take a little cutting and welding. Also, I'm looking for recommendations on new wiring harnesses for an LS swap, any issues with the painless 28 circuit harness connecting to the LS engine harness? Keeping fuel injection. Thanks.
Old Feb 24, 2016 | 10:50 AM
  #1570
im using the PSI conversions harness and stock ecu from donor vehicle, the harness was mint and had all the proper sensors (have not fired car with it yet tho)
Old Feb 24, 2016 | 09:52 PM
  #1571
1970camaroRS's Avatar
I used a PSI harness as well. Been using it for two years and just took my LQ4 out to replace it with a 408, all of the connections were still strong and the harness held up great to daily driving. I'd say it's not much better than a DIY using a stock harness, but it's plug and play.
Old Feb 25, 2016 | 04:54 AM
  #1572
z71yacht's Avatar
I'll have to look that one up
Old Feb 25, 2016 | 05:25 AM
  #1573
z71yacht's Avatar
Thx,
i'm seriously gonna have to check these guys out.
Old Feb 25, 2016 | 09:44 AM
  #1574
Thx,
ya man for sure i called and the guy jeremy i think name was, helped out lots knew what to ask so the harness was built right and so far it has matched perfectly
Old Feb 26, 2016 | 05:50 PM
  #1575
upflying's Avatar
That's what I plan on doing. Run a string and then bring the string to Auto Zone/PepBoys/Oreilly/Napa to find a belt that fits.
Old Feb 27, 2016 | 03:03 PM
  #1576
Another method is to use and old belt, cut it, run it around the pulleys and over-lap the cut end pulling tight until snug with the tensioner in the correct orientation, mark it and cut it down to size and then measure the result. I'm 2 for 3 doing this and getting the correct size the first time. If it's wrong, go back and try, try again.
Old Feb 28, 2016 | 09:59 AM
  #1577
ahh good call i will try this method for sure thx
Old Mar 8, 2016 | 08:48 PM
  #1578
black02-z28's Avatar
I am trying to use the MuscleRods B-body mounts to put a 2000 LS1 with the LH8 pan into a 1980 El Camino. The block side mounts are clearly labeled which way up. Trying all sorts of ways on the K-member mount, but no matter what I do can not get it to line up. The best I have gotten is the mounts seem about an inch too far out line up. Here are some shots of the closest I have been. Seems most I can find are people using the 1" setback with SBC mounts, no good photos of how these go in. Anyone have any ideas?
http://www.brphotrods.com/products/7...cts/index.html
Old Mar 8, 2016 | 09:06 PM
  #1579
Randy_G's Avatar
Those look just like the ones I put in my G-body.. I have pictures of where the bolts go but for some reason they wont upload. Message me I'll email them to you.
Old Mar 8, 2016 | 09:16 PM
  #1580
did find some really good pics here, will compare to what I did. Looks pretty close:
http://hotrodregal.com/brp-hot-rods-...il-pan-part-1/
