The G-Body Swap Thread
Old Mar 26, 2016 | 06:59 AM
  #1601
user 4737373's Avatar
Originally Posted by G-BODY-JAMES
pretty much got the column shift linkage figured out now!!! th350 trans with the hooker/holley LS swap stuff
1985 Buick Regal G Body Supercharged LS3 Swap Part 8 - YouTube
Looks like you've gotten just about everything worked out G-BODY-JAMES...glad to see to see it coming together for you.
Old Mar 26, 2016 | 05:00 PM
  #1602
G-BODY-JAMES's Avatar
Ya now maybe you can design a shift linkage based on my design!!! Haha thanks for your input on things it was a big help!!!!
Old Mar 26, 2016 | 06:17 PM
  #1603
No problem on the input, it's the main reason I create these threads. We don't currently offer any shifter products, but you never know...if you ever get to work out the shifter linkage for a 4L80 you'll experience an even bigger challenge.
Old Mar 28, 2016 | 11:42 AM
  #1604
Tahargrove27's Avatar
Default 01 tahoe 5.3 lm7 swap into 80 cutlass
I have a 1980 olds cutlass was wondering what kind of cam heads and intake i can bolt on to the 5.3 to give me more horsepower... Daily driver but something i can hit da gas and get moving...
Old Mar 28, 2016 | 02:36 PM
  #1605
hey a question on the hooker g body ls swap trans crossmember i have the crossmember and ordered the 12650hkr adapter kit i believe this was the th400 adapter correct??
and... now that i have it it is simply a block of aluminum with some bolt holes and a steel bracket sort of deal that has no holes for bolting... is this a weld on piece? and is this what i need for the th400?? (installing th400 at a later date)
Old Mar 28, 2016 | 02:43 PM
  #1606
You can discard the weld-in gusset, it is used for installing a 2004R in a 1st-gen F-body application. The kit is sold for multiple uses/applications.
Old Mar 28, 2016 | 02:52 PM
  #1607
Default So the aluminum block is necessary for th400 in g body. That's what I needed?
Old Mar 28, 2016 | 03:27 PM
  #1608
Yes, the aluminum spacer is the only part you need to put a TH400 in your G-body with the Hooker crossmember.
Old Mar 31, 2016 | 09:20 PM
  #1609
ok fired car twice today with new air intake and MAF installed
threw 2 codes both times today p0171 and p0174 i believe these are too lean bank-1 and too lean bank-2 anybody get these codes after a swap?
Old Apr 1, 2016 | 01:37 AM
  #1610
1970camaroRS's Avatar
Open headers will do that.
Old Apr 7, 2016 | 09:30 AM
  #1611
upflying's Avatar
Ok, I know I read it somewhere but finding it again is tedious. Just confirming a '98-'02 Generation 4 F-Body radiator fan is the correct part for my Monte Carlo? I'm using the stock radiator. Besides sourcing from the wreckers, is the Dorman #620-634 correct? http://www.dormanproducts.com/itemde...SEName=620-634
Thanks in advance.
Old Apr 13, 2016 | 12:35 AM
  #1612
yep i put on 3 foot chunks of old exhaust ran the car half an hour no lean codes so looks like im customizing the stock crossmember for now to accomadate some chunks of exhaust pipe
but now a damn p0300 misfire code!!!! took her down the road and it was missing hard after 3000 rpm so here we go again haha
Old Apr 18, 2016 | 06:29 PM
  #1613
gula187's Avatar
Besides the engine and transmission what is a ballpark figure on the cost to do a swap?
Old Apr 18, 2016 | 10:16 PM
  #1614
10 g for mine haha (canadian) but there is way cheaper ways to go about it
Old Apr 18, 2016 | 10:22 PM
  #1615
gula187's Avatar
I didn't think it will be that much lol
Old Apr 25, 2016 | 11:11 PM
  #1616
ok shot in the dark here.........
now that the car is done and running what seems to be great!! ive taken it out a few times and have found out that it is now hitting the rev limiter at 5000 RPM!!!! the rev limiter was set at 6500 or possible slightly higher in the 2010 camaro it came out of so i am very confused as "PSI Conversions" (flashed out VATS from ECU) swears that they did not touch anything in the tune... (i will get it tuned again) But i want to know if anyone else has experienced this or heard of it? ive hear that the ECU can have a safety that only allows 5000 rpm when engine is below operating temp but my engine was at 190* so.... anyone??? anything????
also my last swap video
Old Apr 30, 2016 | 08:32 PM
  #1617
kevin87turbot's Avatar
[QUOTE=G-BODY-JAMES;19238063]ok shot in the dark here.........
If the ECM doesn't know that the Trans is in a drive gear, then it resorts to a lower rev limiter setting. My 2012 L99 Camaro had a 6200 rev limiter in any drive gear, but it was only 4000 in Park or Neutral.
There is also a coolant temp and time based modifier table that will affect the limiter.
Both are easy tuning fixes.
Old May 1, 2016 | 12:33 AM
  #1618
[QUOTE=kevin87turbot;19244151]
Ok yes upon some research I found that neutral rev limiter info but only found it about the auto cars... Any confirmation that the manuals rev limiter in neutral is around 5000 rpm??? Obviously they wouldn't want someone slamming an auto in gear with high Rpms but in a standard trans it is more "acceptable" per say haha
And as for the coolant temp it is seeing the proper temps as I'm using an OBD2 reader guage so I can see that
But what is this time based table you talk of???
The ecu has been sent in to the original tuner (Davenport Calgary) for them to have a look over it so hopefully they can change these settings but I will fine tune it here at home on the dyno and a tune
Old May 1, 2016 | 10:01 AM
  #1619
[QUOTE=G-BODY-JAMES;19244311]
Oh, I didn't realize you had an LS3 computer. The table that is causing your problem is the Wheel Speed Limit table. If the PCM doesn't detect at least 14.9 mph as the lowest wheel speed, then it limits the rpm to 5000. It's an easy fix for your tuner.
Old May 3, 2016 | 01:01 AM
  #1620
[QUOTE=kevin87turbot;19244507]
thanks!!!!! ill let ya know what happens
