The G-Body Swap Thread
Its a 2003 fullsize van 6.0 with 30k. Its the motor, wiring computer and transmission for 1500. I am asking 1200 for it. I already talked to the guy and im hoping he will do 1200, that would be good for me and my brother to do 600 a piece to get it.
My question though is, I went on car-parts and it didnt give me a ''ly6, lq4, lq9'' ect engine code so I am alittle unsure what came in these trucks. I know its a 6.0 but im just interested in the details.
Now another question is, I know there are two different throttle types, the one is the dbw where you need the entire pedal assembly b/c its a sensored powered throttle correct? The other is the traditional cable correct? If so, which was this motor equiped with and what do you need to do to get them to work with the gbodys?
And lastly, being a 6.0, we want to do the car intake top end, what intake (thats not like a fast 90) where its expensive as hell, but a intake that will perform with these motors, and actually can be mounted to the 6.0 that will give power or atleast retain the power the truck intake came with? Im not worried about a aftermarket intake for the motor, just want it for looks right now since a intake is later down the road, so a stock lsx intake is fine for now. Thanks Justin.
if its a 03 6.0L that came out of a van its an Lq4 with a 4L80e transmission. with 30k on it as long as the oil changes were done it should look great internally.
I have a 04 lq4/4L80e that had 40k on it, i opened up the valve covers it looks almost new.
That 03 van motor is drive by Cable. You will need to get a new cable , I am going to use a Lokar cable, and I also have the Lokar 4L80e transmission dipstick.
I am running the Edelbrock Pro flo Xt intake which is very reasonable priced, and I had maybe an inch or so room left to spare on my GN.
I called Current Performance who did my wiring and computer for my lt1 s10. He would build me a custome harness and reflash the computer. So thats good, since I plan to swap to a ls6 intake. SO things will lay correctly and plug and play. Now I know with going with teh ls6 intake you need to use the injectors and fuel rails as well. Is that it for the intake swap besides the front accessories modding?
On to the front accessories, I plan to keep all accessories including AC/PS so with saying that, If I do not go with a vette setup, KWPERF or however you spell it does the relocating the the accessories to allow the car intake to have no restrictions. My question is which ''bracket'' do I need from them for this? And also, with having PS what do I hve to do with clearing the steering box? Since I have read about clearance issues with the box. And If i needed to notch the frame on the passenger side, thats fine we did it for my s10.
NOw I have read both good and bad reviews with going with the pacesetter 98-02 LT headers...I cant justify dropping 700 dollars for headers right now but from what I read the pacesetters fit decent with the right mounts. ANd IIRC, its the stock clamshell mounts with the sbc->lsx adapter plates? If so which companys work best since I will be using all stock accessories upfront.
Cooling, I read that the champion all aluminum radiator is a decent radiator...I was thinking using that and ditching the cheap looking fans for 98-00 intrepid fans. Over on the s10forum they are popular and are said to have two styles, one which is a low/high 3000/3500cfm and the other is a low/high 3500/4000cfm puller fan setup with them built into a shroud already.
fuel tank I read that you want to get a ls 4.3 FI tank, and swap a aftermarket fuel pump. I already have a walbro intank pump, so this should work good correct?
Still a huge noob but I am trying to figure out the best way before we jump into this.
I put 'em on tonight (87 Regal). The pass one is going to need a little adjustment with my framing hammer, but they are good to go!
.. but ended up taking it to my local exhaust shop and having them replace and move the new tube inward to miss the frame I called Current Performance who did my wiring and computer for my lt1 s10. He would build me a custome harness and reflash the computer. So thats good, since I plan to swap to a ls6 intake. SO things will lay correctly and plug and play. Now I know with going with teh ls6 intake you need to use the injectors and fuel rails as well. Is that it for the intake swap besides the front accessories modding?
I think I have hit $3000 total for the swap - maybe a bit less. The motor is stock internally.
The stock truck accessories DO fit under the hood.
Here is my build thread! http://m.modernhemi.com/forums/showthread.php?t=1362971
1987 Monte carlo LS
Passenger side:
Stainless ebay header = NO WAY
Pacesetter Truck Header= YES with minimal massaging
Driver side:
Pacesetter Truck Header= No Way....does not stay tight enough to the engine
Stainless Ebay= Did not try
I know most everyone has said the pacesetter f body header works good on the driver side, but it still isnt the answer I am looking for. I am wanting something only to look nice, and stay nice as long as I can since this car isnt my race car. The rusty looking manifolds just have to go!
1987 Monte carlo LS
Passenger side:
Driver side:
Do you have any pictures of the way you put the F-body compressor on the car with the stock brackets? BRP says that I could of used the stock F-body components with their mounts, but they also didn't say I needed to drill 4 new holes for my trans crossmember. I would love to use the stock GM setup especially now that I have a billet Katech tensioner.
http://api.viglink.com/api/click?for...%3Ft%3D1362971
The trick is you have to move the SBC lower mounts back on the frame and then build your own upper mounts to make that work.
