The G-Body Swap Thread
That is a Non-AC Box too..
That's all you get till the build thread..
What's up with the Fuel Tank thing there? I have a vent already on the Tank so will I be good?
I apologize if this has been covered already but I haven't seen it in my searches.
How is everyone wiring up their SES, seatbelt and high beam lights in their Monte SSs? I am assuming that the printed circuit needs to be removed especially since I am running AutoMeter gauges and the back of the housing needs to be cut to fit them. So how can I power these bulbs? Is it possible to solder a wire to the little tabs that are used to make contact with the printed circuit?
Also if anyone can take pics of how they mounted their truck DBW pedal into the car that would be great because I am currently looking for ideas to mount mine.
Car is a 87 monte ss and the engine is a 2004 5.3L with DBW.
Thanks for any help
Thanks for any help
Anyway.. for all to see here is a 3 row champion with aluminum two fan shroud and fans that I paid a little over 500.00 for the whole shabang..
Things I liked:
1. Fit in the stock position with the Buick Fan\Rad top mount bracket.
2. Had a threaded fitting for the steam vent tube (pictured here with brass barbed fitting)
Yes I know there are other cleaner options.. This is the route I took..
3. Good craftsmanship.. Nice welds and a quality piece for the price..
4. Clean OEM look...
Things I didnt like..
1. No provisions for fan holes in the shroud... Not a big deal as the fans made for an easy template Edit: By "Holes" I meant the 4 mounting holes at each corner not the main holes open to the Rad..
2. No hardware was given to mount the fans to the shroud.. The guy that sold it to me on ebay refunded me the amount I spent at the hardware store so no biggie.. I was amazed he even offered.. I was just mentioning to him as an FYI and he responded with the offer..
3. Fans seem a little on the cheap side (Just my opinion)As I really dont know what to expect as far as the life expectancy as I dont know what the critical moving componenets are comprised of. Edit: I did try the fans out.. As for the operation.. I had no issues.. They are quiet and move the air effectively as described in flea-bay..
Shot at 2011-01-20
I have this radiator ordered from Summit, but if they move the ship date back one more time I'm going to cancel the order and get something else.
http://www.summitracing.com/parts/GR...8-LS/?rtype=10
Car: '84 Monte SS
Drivetrain: 5.7L LS1 and 4L60E from '01 TA w/ 52k miles. Bought from Cleveland Pick-a-part
Goal was a close-to OEM installation without cutting the car. I wanted to retain a totally stock interior appearance, too.
Radiator: Stock g-body w/ extra nipple for steam hose. G-body Cutlass top radiator retaining bracket. F-body LS1 fans w/ custom brackets for attaching to factory retaining clips. Buick Grand National A/C condenser- passenger side connection and same brackets as MCSS.
Intake: DIY parts from Silicone intakes.com. Stock MAF.
Engine swap parts: Spohn motor mounts, Kwik A/C bracket, BRP Mid-length headers, RetroLSX oil pan, NAPA G-body temp sending unit machined to fit in rear of passenger cylinder head (Vato Zone sending units deteriorated during machining process, Current performance stand-alone module for engine (chassis uses OEM fuse block). 2.5" 304 stainless exhaust w/ H-pipe and Dynomax VT mufflers. Mufflers at idle and normal RPM have factory F-body sound but roar when you spin up the engine.
Trans swap parts: Shiftworks tailhousing, built-to-spec trans cable (couldn't find adequate OEM part), custom trans cable mounting tab, Iceman x-member (not quite bolt-in application), F-body shifter modified to mount in factory G-body location and use stock MCSS shift handle. No mods were necessary to fit MCSS handle to F-body shifter. Shortened OEM MCSS driveshaft- will eventually replace with new driveshaft.
Electrical: Wait4Me performance flashed the ECM and converted the harness. I intended to do the electrical work myself until a local shop opened, Downriver Motorsports Wiring in Romulus, MI. The rates were exceptionally fair and quality of work far exceeded my expectations and abilities. The ECM is enclosed in a custom housing on the passenger toe-board beneath the carpet. The passenger loses about 2-2.5" of legroom.
I have a 34" inseam and could sit comfortably. Also had car dyno tuned. In hindsight, I paid twice for the harness and ECM flash, but it was a relatively inexpensive lesson to learn.
Fuel delivery: Buick Grand National gas tank/fuel pump/sending unit/, 'vette filter/regulator, currently have -6AN line from tank to engine but have plastic line to replace it when the weather breaks.
Fittment: RetroLSX pan is the cat's ***. Front cross-member is ~5" off the ground and the pan is tucked from harms way. ~1/8" clearance between stock steering box and alternator pulley. Pass rear spark plug is touching A/C box. I plan to clearance the box when the weather breaks. The engine-to-AC clearance is why the harness is draped over the rocker covers. BRP headers would have melted the OEM steering shaft. Jeep XJ steering shaft was too bulky, so I got it right with Borgeson hardware. Clearance is still a scant 1/8-1/4". BRP header flanges negated use of stock trans cable mounting tab.
Lessons learned: I'd not buy a harness or tune twice, and I'd opt for making my own trans x-member or just buying a G-force unit. I bought the Iceman used but never installed and didn't receive paperwork with it to know if I had the correct application or not. Unmodified fitment was like a saddle on a cow, but it worked out fine. I'm very satisfied with the end result. In hindsight I shouldn't have pussed out and cut the car. Had I gone that route it would have a T56.
Other stats: SC&C Stage 2, SPC tubular lowers and springs (all corners), SC&C frame brace, Vari-Shocks on all corners, Currie upper and lower rear arms, Baer Track 13" kit on OEM spindle, Baer Track 12" kit on rear, 18" Rushforth Fuel on Khumo Ventus tires.
Open issues: headliner repair, driveshaft replacement, purchase DIY A/C lines & charge system, wait for snow to melt and enjoy.
Keep up the good work guys!
Nice.
