The G-Body Swap Thread
I have an 80 in my Monte. I also have the BRP shorty headers. The 80s have "ears" on them at the bottom of where the trans bolts to the engine. These "ears" are to attach the torque converter cover (I think) and can be easily chopped off with a grinder or reciprocating saw. Remember that the housing is aluminum and will probably load up on any tool you use so have extra saw blades or cut off wheels at the ready. It also helps to test fit headers on the engine/trans combo while out of the car...or you can do it the hard way like I did and cut them off while its all in the car
https://ls1tech.com/forums/conversio...-features.html
My hood closes but it is very close. I also have the engine mounted as low as possible, I`m running a f-body oil pan which is the shortest GM pan available and the pan sits less than 1/2" above the k-member
. Did you find the El Camino swap thread? Theres a bunch of pics in my fquick account and a video
