The G-Body Swap Thread
For me, I want it all.. Full funtion.. AC, Cruise, and the power, of course, to boot..
Additionally, my guess is, at one inch back, that you might have problems retaining the stock crossmember location.
Matt
I've got a ls1/4l60e in my ls and with the BRP kit the trans crossmember sits just forward of the factory position, but I'm going to have to get the stock driveshaft shortened some if that helps you any.
Glad to hear it worked for you. Lets see some pics. NOW!! LOL
Here's a shot of the old crate 350 being pulled. I say old, but it had only 5,000 miles on it.
Here's the 5.3/4L60E coming home from the salvage yard
I modified the heat/AC box to clearance the valve cover and coils
All cleaned up and ready to go!
Here's the final install. It's a good fit, and in hindsight, not that much work.
The next steps are to find or fabricate some kind of intake, top of the fluids, go for a ride, and do a little tuning!
I might be able to get a few pictures for you of my swap. Its almost complete, but lacking a few things. You are right, the valve covers are close to the heater box making the coils real close. I swapped them out for a set of truck coils (the good ones) and haven't had any problem. They sit higher up on the cover.
Here is the old going out....
Here is the LS2 from an 05 GTO with Howell engine harness and TAC module which will allow me to use the Drive by wire function and cruise.
Inspired by John Bzdel... Here is the FI tank from a 4.3 litre monte with the desired baffling and FI sending unit.
John had mentioned the restriction on the TBI fuel sending unit ( Feed and return)so I knew that some changes were needed.. Here is the sending unit after I gave it a little sand blasting.
Here pictured with the 3/8 feed and power plug off along with new 3/8 and 5/16 lines for replacement.
Although similiar to what John had done I wanted to go a little different direction in that I wanted nylon quick connect lines from the tank ( 3/8 feed and 5/16 return) to the corvette regulator. The reason is 1.) I wanted to be able to easily service the filter\regulator. 2.) I wanted to run nylon all the way up to the fuel rail.
With this in mind, I borrowd my brothers flaring tool to put the standard rolled edge you see on Fuel rails, on the new feed and return lines. The one on the far right is the stock 5/16 vapor line that will remain in the same position on the frame.
The hardest part was the return line because its used to support the pump assembly with a ring tacked on to the bottom of the return line and also has the gas gauge sending unit mounted to it.. Rather than mess with that I cut off the top of the old return line, sealed it, and plumbed a new return behind it..
One other item, I had to remove the plastic connector\ power plug that goes through the top of the sending unit so that I wouldnt melt it into oblivion when attaching the new lines. Theres a special fastener thats used to anchor the plug tight as there is a rubber seal on the bottom of the connector. I call it the "Damn it" fastener. Allow me to explain... This bugger is so tight on there I had to pry it off... without destroying the plug... at which point it snapped and from then on became the "Damn it" fastener..
Which quickly turned into the "Damn it, where do I find one of these?" fasteners.
Its similiar to the fastener used in a standard distributor when I had to change the pick-up coil, but unfortunately it was a different size..
As luck would have it.. I was able to dodge a bullet and find one in a multi pack in the HELP!! Items of my local auto parts store...
More later as progress and time permits..
