The G-Body Swap Thread
Old Sep 15, 2009 | 12:15 PM
  #181
2Aspire's Avatar
Moved the engine off of the cradle and on the rotisserie to add CTS-V pan
(Complete with dino drippings) Is it too early for Thanksgiving?
One of the issues I ran in to swapping the GTO pan to the CTS-V pan was the GTO pan has the dip stick hole integrated into the pan. What I found was that there is a plug that you just need to tap out in the LS2 block with a punch to use the CTS-V oil dip stick..
Here is the location of the hole for the CTS-V dipstick
Old Sep 15, 2009 | 06:48 PM
  #182
Monte LS....1's Avatar
sorry its taken so long to post the pictures but here they are anyways...
Old Sep 20, 2009 | 07:26 AM
  #183
81cuttysupreme's Avatar
ah ha. those are the pics i needed. i can clearly tell the steering box is different than mine. i'm going to try to get a GN box, which looks the same as that one. The shape of the steering box in my car wasnt giving me enough clearance on the alternator. Thanks for the pics.
Old Sep 20, 2009 | 07:27 AM
  #184
now i have to figure out what to do with the heater box. i'm thinking of just trimming it back alittle. there's not room to get the #7 plug on the coil.
Old Sep 20, 2009 | 02:32 PM
  #185
Monte4ever's Avatar
I'm putting a 403 based LS motor in my 82 Monte also, however I'm building my motor from scratch. I've done a few modifications to my frame which include notching the front crossmember. As for motor mounts, I'm going with Spohn which looks to be close to John B mounts. Someone in another thread (forgot who) stated that TSP headers fit very good and the only modification needed was the trimming of the ears off of his TH400trans. He was also using mounts that placed the motor in the stock location.
Old Sep 21, 2009 | 08:22 PM
  #186
topher455's Avatar
Nice work boxing the frame in. I did it and it was definitely worth it.
Old Sep 22, 2009 | 08:36 AM
  #187
Monte4ever's Avatar
Thank You 455.
Old Sep 22, 2009 | 09:48 AM
  #188
cudaeh's Avatar
ok just ripped thru this whole thread.
im getting my ducks in a row for a possible el camino swap project...
is there any good cheap disc brake rear end we could use for the swap?
Ive seen the grand national rear axle with a disc conversion used a fiew times, but the gn axles arnt in every junk yard, and the conversion kit seems to be another high ticket item to buy... I was wondering if there is a good donor axle that will swap right in? s10? Silverado? other brand like a dodge derango?
Old Sep 22, 2009 | 06:29 PM
  #189
Not a problem on the pics...I also thought I was gunna have clearance issues with the heater box, but I swapped the F-body coils and brackets out for a set of the truck brackets and coils. Don't know if the ones without the heatsinks would help alot, but the one's with the heatsinks on the top of the coil sit higher on the valve cover toward the intake and they clear pretty nice. Guess that would all depend on motor location and such as well
Cudaeh...i swapped the rearend of my monte for the GN like you mentioned and actually used some LT1 camaro disc brakes... just gotta drill two holes and have the brackets the bolt to the rearend cut down some so the disc doesnt hit the caliper bracket
Old Sep 26, 2009 | 02:24 PM
  #190
What's everyone using for a set of headers...I know BRP and Edelbrock make a set. Edelbrock even makes an entire exhaust...any one use it?
Old Sep 27, 2009 | 10:07 AM
  #191
topher455's Avatar
Modified pacesetters for a 4th gen. I didnt have the funds for those expensive swap headers. If you have a welder and a spare hour or two you can do it. Or dent a few tubes and youll be done in 20 min.
Old Sep 27, 2009 | 11:44 AM
  #192
Yeah I don't have the money right now either...really would like to take the car to the lsx shootout so not sure what I'm gunna do. Just few more things left and it'll be driveable, but not completely done.
Old Sep 30, 2009 | 01:53 PM
  #193
koaea's Avatar
Default heater box removal??
I've been looking high and low, and can't find how to remove the lower heater box off our G-bodies. The top comes off easily, and I've unbolted the lower from the firewall, and removed the linkage to the ac/heater flapper valve, but there's still something holding it in!
The whole box moves up and down a couple inches, but I'm not sure if there's something inside that needs to be removed? I don't want to mess anything up, just want to take it out, so I can fix my shoenfeld headers in, then modify as needed.
I made my own adapter plates to fit to the stock a-frame clamshell motor mounts that set the engine back a few inches.
thanks in advance!
Old Sep 30, 2009 | 02:11 PM
  #194
topher455's Avatar
It is a pretty massive unit. Alot of it is behind the dash. I had my front clip off when I took mine out so it was easy. You may have to pull the dash but it has been so long I cant remember.
Old Oct 1, 2009 | 05:48 PM
  #195
OK, i have the engine sitting in the car, with the BRP mounts and the K member cut. F body engine and oil pan. My dilemma is the AC compressor. The back hits the frame and there is minimal clearance on the side. I'm wondering if there is a sanden compressor that solves this problem? anyone know?
Old Oct 1, 2009 | 06:09 PM
  #196
topher455's Avatar
Either mount it high up or notch the crossmember are the only solutions I know of.
Old Oct 1, 2009 | 09:58 PM
  #197
Put the wheels and tires on and set the car on the ground...the left rear tire rubs the frame rail some but the right rear doesn't? Any ideas why? I've also got some problems up front...any bodies car have a huge gap between the fender and top of the tire. My car looks like its got a lift kit in the front and is four wheel drive. Is the ls motor really that much lighter or is there another reason for this?
Old Oct 2, 2009 | 07:39 AM
  #198
John B's Avatar
Moderator
The rear is probably in a bind from being on jack stands and will re-center itself after you move the car a few feet....same story up front, once you roll the car either forward or backwards several feet the car will re-settle and the large gap between the front tire and fender will go away. The weight difference with the LS motor may raise the front about 1/2" over the stock motor once settled.
Old Oct 2, 2009 | 07:19 PM
  #199
topher455's Avatar
Couldnt have said it better myself.
Old Oct 3, 2009 | 09:29 AM
  #200
Awesome thanks. I have one question about the rearend though...in the rear, I had the jackstands under the frame rails still from where I swapped out rearends so could that still be the problem there?
