The G-Body Swap Thread
Old Apr 7, 2014 | 06:07 PM
  #1181
llorracs93s10's Avatar
another dumb question but for you guys that but the hot wire kit, what is the process of wiring it complete? Besides the obvious hook up to the sending unit and run it to the alternator.
Old Apr 8, 2014 | 08:16 AM
  #1182
bigmandengo's Avatar
You are going to need the pigtail that plugs into the fuel sender out of an efi g-body (grand national/4.3 monte). Splice that into your fuel gauge wire, ground and then run your fuel pump wire from your ecm to the last pin on that connector. Then it will be plug and play with a racetronix hot wire harness or the stock sender.
Old Apr 10, 2014 | 01:20 AM
  #1183
Da Reazon's Avatar
Is everyone having to slot holes and such when using the 1" setback plates and clamshells. I am looking for a 1" setback bolt in setup
Old Apr 12, 2014 | 07:39 AM
  #1184
Docked Wage's Avatar
Got my regal back from the paint shop so I can finally get the swap started.
It's getting an LQ4 and a 4L80E from a wrecked Penske Cube Van with 87k on it. The plan is to be a cam only motor and the trans is getting a 3000 stall convertor from Circle D. If It does not get into the 12's I'm going to spray it.
It's also getting a 2004 Ford Mustang Mach 1 8.8 rear axle, S10 Front Spindles, Vette Brakes up front and a bunch of other upgrades along the way.
This one is going to take a while....
Old Apr 12, 2014 | 06:06 PM
  #1185
looks good man. I have the wheel well tub out of the passenger side so I can see for sure if the standard mounts would work with the headers.
Old Apr 12, 2014 | 10:16 PM
  #1186
Thanks Justin. Need to push the button and buy those headers but there are piles of parts everywhere and I need to start bolting stuff back on so I have some room.
Thanks again,
Old Apr 13, 2014 | 02:59 PM
  #1187
HeadGames Dave's Avatar
anyone use a built 2004r from the GN for a little bit? I have one that I used in my Buick from 98' with a Art Carr 3800 stall that is all fresh.
I have twin 61's with a built 408 I am planning on using, but thinking about just getting it running and driving running it N/A for the summer so I can cruise it sooner! 10.1 comrpession with trickflows with a small cam should be good for low 11's I gander with the 2004R. If I can get 2 months out of the trans I would be happy.
Old May 7, 2014 | 02:56 AM
  #1188
VegasLife's Avatar
what are u guys using for throttle cable?
Old May 7, 2014 | 04:27 AM
  #1189
6LITEREATER's Avatar
I got the longest cable a local bicycle store had. Has the cam on the end and everything...
Old May 20, 2014 | 10:45 PM
  #1190
ryanleiker's Avatar
Tell me more about this. Pictures?
Old May 21, 2014 | 07:09 PM
  #1191
kad5118's Avatar
here is mines in the works as we speak
Old May 23, 2014 | 10:58 AM
  #1192
As soon as I get the TB back on I'll snap some. Basically it is just a black bicycle brake cable...
Old May 24, 2014 | 10:21 PM
  #1193
Mt.Dew's Avatar
ls1 Camaro throttle cable. it needs a slight skim with a dremel. Pops right in, looks factory and $25 new.
Old May 28, 2014 | 02:36 AM
  #1194
Alrighty, for the Torque Converter wire coming out of the computer, what are you guys hooking that to? Can we wire it right to our brake switch (if so which wire?) or do we need to run a relay of some kind?
Old May 28, 2014 | 02:50 AM
  #1195
Lol, I search for two weeks, find nothing. Post a queston. Search again find my answer lol. For anyone else who needs to know, here's the switch to buy and how to wire your Torque Converter lock switch...
Old May 28, 2014 | 03:02 AM
  #1196
1970camaroRS's Avatar
I have one of those sitting on my shelf in the garage. Bought it before realizing that the stock switch on cruise-control cars works just the same.
Old May 28, 2014 | 11:15 PM
  #1197
Picked mine up today, under $9 with tax and Auto Zone part number still works...
Old Jun 2, 2014 | 07:17 PM
  #1198
89LS1FOXER's Avatar
Just starting mine, voice your opinions if any of you get time!
https://ls1tech.com/forums/conversio...l60e-swap.html
Old Jun 3, 2014 | 01:57 AM
  #1199
Stage 1 done. Everything installed and running, body fab done...
Next I have to fix a few hiccups (water pump neck we made needs welded) also, does anyone know why when I hooked up the firebird brake switch now my DRIVER SIDE brake light doesn't light up???
My stock switch had two wires on the back, three on the front. I thought back were CC, left unplugged. The three on the front I knew one was hot, one went to third brake light one went to brake lights (I thought). Wire the two brake ones together. Third brake light and PASSENGER SIDE brake light work. Driver side does not and it has new bulbs...
Old Jun 3, 2014 | 12:37 PM
  #1200
89LS1FOXER's Avatar
Looks killer man!
