The G-Body Swap Thread
Old Jul 27, 2014 | 09:09 PM
  #1221
onebadbowtie86's Avatar
Is there any preference on which high mount alternator kit to use to move it up? looks like this may be my only option with using the stock gto alt.
Old Jul 28, 2014 | 09:24 AM
  #1222
user 4737373's Avatar
Originally Posted by onebadbowtie86
does anybody have any pictures of f body accessories in a g body? Specifically looking for alternator to steering box clearance.
I have an ls2 out of a gto and it has the Mitsubishi alternator that has a longer clutch style pulley on it and I'm a little concerned with if it will fit or not.
Here's three images that show the clearance between the 4th-gen F-body alternator and stock steering box when using the new Hooker engine mounting brackets...you may just get lucky with your GTO alternator as there is still room to spare.[IMG][/IMG] [IMG][IMG][/IMG][/IMG]
Old Jul 28, 2014 | 12:56 PM
  #1223
6togo's Avatar
How close is the engine to the firewall?
Old Jul 28, 2014 | 01:41 PM
  #1224
I did not measure that distance during the mock-up phase, but I can get it in about a week once the car starts being reassembled. As a point of reference, the coil bracket on the right side cylinder head is 1/4" to 5/16" away from the A/C evaporator case.
Old Jul 28, 2014 | 05:59 PM
  #1225
jimmyg's Avatar
Default Mounts
That sounds perfect I was worried about heater box.. trying to fig out how u guys lowered engine height with your mounts the clam shell part must be shorter than sbc mounts may be frame mounts also?
Old Jul 28, 2014 | 07:13 PM
  #1226
You have the basic gist of it down...the Hooker engine brackets are designed with lower installed geometry than you can get with using the stock SB Chevy engine side brackets and the typical flat LS swap plates. Using the sliding universal type brackets puts the engine up even higher as their adjustability comes at the expense of increased thickness.
Old Jul 28, 2014 | 07:16 PM
  #1227
How far set back are the hooker mounts? I was planning on using 1" set backs so my transmission stays and the same position. Looks like I'll need the high mount bracket for the gto alternator.
Old Jul 28, 2014 | 07:19 PM
  #1228
bigmandengo's Avatar
The gto alternator should fit in the stock location with setback plates.
Old Jul 28, 2014 | 08:02 PM
  #1229
llorracs93s10's Avatar
So if you go with the F body accessories or even the GTO ones, what PS lines do you plan to use?
Old Jul 28, 2014 | 08:06 PM
  #1230
I guess I'll try it and if it doesn't fit I'll move it up. Hopefully some one else has a picture of the alternator clearance with 1" setbacks. Unless that's what the hooker mounts are?
Old Jul 28, 2014 | 08:08 PM
  #1231
I'm not sure about what ps lines, or radiator hoses to use.
Old Jul 28, 2014 | 08:16 PM
  #1232
Lower hose I used a 03 tahoe and upper for my l99 water pump (ls3 camaro water pump) I used the one in my build thread. I have the part number somewhere in the thread. But if you use a truck pump, my upper will not work since mine is on the driver side of the motor rather both inlet/outlets on the passenger side.
Old Jul 28, 2014 | 08:29 PM
  #1233
I've used setback plates with f-body accessories in the past and there were zero clearance issues. As far as I am aware, the gto alternator is spaced the same as an f-body and is in the same location. Post up what you come up with.
Old Jul 28, 2014 | 08:32 PM
  #1234
The issue with the gto alternator is that it has a clutch built into the pulley. So the pulley is about twice as deep as an f body alternator.
Old Jul 28, 2014 | 10:33 PM
  #1235
Fry_'s Avatar
The Hooker mounts are 1/4 inch set back.
Old Jul 29, 2014 | 02:57 AM
  #1236
The set back of the Hooker mounts is approximately 1/4", so they will not work for someone who wants to leave their transmission in the stock location. There is a list of multiple issues that result from using a 1" set back in this application when you factor in the various transmissions that are used and I can only see the benefit being for someone determined to keep their 2004R in the stock location so they can reuse their stock driveshaft. You can get the engine in with 1" set-back plates, but you have to remove or notch the A/C evaporator case to do so and your engine inclination angle will not produce desirable U-joint working angles without.cutting up the trans tunnel and rebuilding it.
Old Jul 29, 2014 | 03:06 AM
  #1237
For everyone's benefit, I will test fit a GTO alternator into our Monte Carlo SS as it gets reassembled next week to confirm its compatibility with the new Hooker engine mounts and crossmember.
Old Jul 29, 2014 | 08:12 PM
  #1238
Wow that would be absolutely great! Thanks so much!
Old Jul 31, 2014 | 01:00 PM
  #1239
86slicksilverss's Avatar
Toddoky, are y'all going with the r4 or Sanden a/c system?
Old Jul 31, 2014 | 01:27 PM
  #1240
I've not heard one way or the other yet, but it will be sorted out by LS Fest.
