The G-Body Swap Thread
Old Nov 10, 2015 | 04:44 PM
  #1421
streetknight2's Avatar
Originally Posted by tdishon
Yes and yes
Any pictures or info about the way things are routed?
Old Nov 20, 2015 | 08:16 AM
  #1422
HeadGames Dave's Avatar
Originally Posted by streetknight2
Who has a Turbo LS G body? Can you keep power steering and A/C?
power steering is not issue. A/C options suck.
Old Nov 20, 2015 | 08:27 AM
  #1423
bigmandengo's Avatar
https://ls1tech.com/forums/forced-induction/1804491-81-regal-5-3-pt7675-build.html#post18984714
Old Nov 20, 2015 | 09:41 AM
  #1424
tdishon's Avatar
I used the Sanden 508 with the Alan Grove block hugger compressor.
Part number 144R A.C.. I had to notch the frame, but it worked great! I have an LSA with twin turbos. A high mount compressor was not an option.
Old Nov 21, 2015 | 02:24 PM
  #1425
jmd's Avatar
jmd
Thumbs up
Not hating, but post some pictures.
I'm not interested in up-high or notch-city.
Old Nov 21, 2015 | 10:56 PM
  #1426
89LS1FOXER's Avatar
Anyone using the UMI frame mounts??
Old Nov 22, 2015 | 01:09 PM
  #1427
tdishon's Avatar
During the mock up, we notched the fame and used the pye-r foam block. You can see the Alan grove compressor bracket.
Old Nov 26, 2015 | 02:33 PM
  #1428
tonytone4143's Avatar
what motor mounts are you guys using?? I have a 5.3l with a 4l80e going into a 88 monte carlo ss. Will be planing on turbo, A/c, and power steering for sure in this baby,
Thanks in advance
-Tony
Old Nov 26, 2015 | 05:52 PM
  #1429
Thanks in advance
-Tony
Stock truck accessory drive including the low mount a/c compressor clears everything with spohn swap mounts.
Old Nov 27, 2015 | 10:01 PM
  #1430
toyin's Avatar
The spohn mounts work good but for some reason the left side (drivers side) mount isn't lining up. I'll be running truck accessories.
Old Nov 27, 2015 | 10:16 PM
  #1431
toyin's Avatar
Not sure what the deal is with the drivers side but it don't line up for ****! I don't know if they're supposed to line up like this but i wouldn't think so. I've seen a couple pictures of the Spohn mounts but they are always the passengers side and never the drivers side.
Attached Thumbnails The G-Body Swap Thread-image1.jpg   The G-Body Swap Thread-image2.jpg
Old Nov 28, 2015 | 10:32 PM
  #1432
tta656's Avatar
Toyin,did i see an -an fitting on the oil pan,,if so do you have better pics ,i want to install mine and want ideas
Old Nov 28, 2015 | 11:45 PM
  #1433
toyin's Avatar
Yes sir! I'll get some more pictures tomorrow for ya. It's just next to the oil level sensor.
Old Dec 1, 2015 | 04:22 PM
  #1434
so the spohn puts the engine forward a few inches?
Old Dec 1, 2015 | 09:40 PM
  #1435
G-BODY-JAMES's Avatar
im having issues please watch my ls3 swap into regal ps/alt issues in this youtube vid
im regalman08 on youtube i need to keep a 2 pin 14 v style alternator please help
Old Dec 1, 2015 | 09:52 PM
  #1436
jimmyg's Avatar
Go online there is a holley fitment guide for that bracket. I don't think the camaro alt will work . Post a pic of the alt plug
Old Dec 1, 2015 | 10:00 PM
  #1437
it doesnt work thats why im on here
Old Dec 1, 2015 | 11:51 PM
  #1438
01cherryreds10's Avatar
James for the holley bracket you need an alternator from a truck that had a 5.3, and you need a 02-05 corvette power steering pump, the aluminum one.
Old Dec 2, 2015 | 01:09 AM
  #1439
so any gm truck that had a 5.3? any specific year that has the 2 pin plug? i need the 2 pin as my harness has the 2 pin plug also the camaro ss stock alternator was a 14V 150 amp so id like to keep those numbers the same...
Old Dec 2, 2015 | 01:10 AM
  #1440
as for the power steering it wont matter as much thankyou i will grab one from a vette
