The G-Body Swap Thread
- my vision for the install was a near-factory hardware installation
- I didn't want to use an aftermarket shifter.
- my stock g-body shifter was for TH350, so the detent plates weren't correct anyways.
- I planned to use a stock F-body trans cable. The F-body shifter has a bracket for securing the top end of the cable.
- to keep the F-body neutral safety switch/wiring.
I was able to fit the F-body shifter under the console by removing excess material from the plate (basically kept the trans cable bracket and shifter-to-plate mounting points). I welded brackets to the F-body shifter plate to pick-up the bosses on the Monte's trans tunnel. I welded a small flat plate on the back of the shifter plate to pick-up the rear attachment point. The icing on the cake was the shifter handles being interchangeable.
Filter is from the LS2 GTO Varaam Kit, it uses the 85mm Z06 MAF. Radiator Support is a piece of 1/8" Aircraft Aluminum bent in the middle with a Sheet Metal Break.
I just read all 22 pages of this read
Awesome thread filled with tons of useful info, pics & links. I have an '82 Cutlass & was contemplating a 400sbc build but after reading this thread I've Finally decided to go with a 6.0 4L80 swap for FI & overdrive. Sure there are some issues to deal with but the time & $$ spent will be worth it to get the car updated with some modern technology.Lots of smart people on here. Thanks to all who have contibuted to this wealth of information !!! The swap seems far less scary now.
Car: '84 Monte SS
Drivetrain: 5.7L LS1 and 4L60E from '01 TA w/ 52k miles. Bought from Cleveland Pick-a-part
Goal was a close-to OEM installation without cutting the car. I wanted to retain a totally stock interior appearance, too.
Radiator: Stock g-body w/ extra nipple for steam hose. G-body Cutlass top radiator retaining bracket. F-body LS1 fans w/ custom brackets for attaching to factory retaining clips. Buick Grand National A/C condenser- passenger side connection and same brackets as MCSS.
Intake: DIY parts from Silicone intakes.com. Stock MAF.
Engine swap parts: Spohn motor mounts, Kwik A/C bracket, BRP Mid-length headers, RetroLSX oil pan, NAPA G-body temp sending unit machined to fit in rear of passenger cylinder head (Vato Zone sending units deteriorated during machining process, Current performance stand-alone module for engine (chassis uses OEM fuse block). 2.5" 304 stainless exhaust w/ H-pipe and Dynomax VT mufflers. Mufflers at idle and normal RPM have factory F-body sound but roar when you spin up the engine.
Trans swap parts: Shiftworks tailhousing, built-to-spec trans cable (couldn't find adequate OEM part), custom trans cable mounting tab, Iceman x-member (not quite bolt-in application), F-body shifter modified to mount in factory G-body location and use stock MCSS shift handle. No mods were necessary to fit MCSS handle to F-body shifter. Shortened OEM MCSS driveshaft- will eventually replace with new driveshaft.
Electrical: Wait4Me performance flashed the ECM and converted the harness. I intended to do the electrical work myself until a local shop opened, Downriver Motorsports Wiring in Romulus, MI. The rates were exceptionally fair and quality of work far exceeded my expectations and abilities. The ECM is enclosed in a custom housing on the passenger toe-board beneath the carpet. The passenger loses about 2-2.5" of legroom.
I have a 34" inseam and could sit comfortably. Also had car dyno tuned. In hindsight, I paid twice for the harness and ECM flash, but it was a relatively inexpensive lesson to learn.
Fuel delivery: Buick Grand National gas tank/fuel pump/sending unit/, 'vette filter/regulator, currently have -6AN line from tank to engine but have plastic line to replace it when the weather breaks.
Fittment: RetroLSX pan is the cat's ***. Front cross-member is ~5" off the ground and the pan is tucked from harms way. ~1/8" clearance between stock steering box and alternator pulley. Pass rear spark plug is touching A/C box. I plan to clearance the box when the weather breaks. The engine-to-AC clearance is why the harness is draped over the rocker covers. BRP headers would have melted the OEM steering shaft. Jeep XJ steering shaft was too bulky, so I got it right with Borgeson hardware. Clearance is still a scant 1/8-1/4". BRP header flanges negated use of stock trans cable mounting tab.
Lessons learned: I'd not buy a harness or tune twice, and I'd opt for making my own trans x-member or just buying a G-force unit. I bought the Iceman used but never installed and didn't receive paperwork with it to know if I had the correct application or not. Unmodified fitment was like a saddle on a cow, but it worked out fine. I'm very satisfied with the end result. In hindsight I shouldn't have pussed out and cut the car. Had I gone that route it would have a T56.
Other stats: SC&C Stage 2, SPC tubular lowers and springs (all corners), SC&C frame brace, Vari-Shocks on all corners, Currie upper and lower rear arms, Baer Track 13" kit on OEM spindle, Baer Track 12" kit on rear, 18" Rushforth Fuel on Khumo Ventus tires.
Open issues: headliner repair, driveshaft replacement, purchase DIY A/C lines & charge system, wait for snow to melt and enjoy.
The motor is from a 07 C6 Vette,
Here is a list of parts i have to complete the conversion
Motor LS2
Tranny 4L65E
BRP motor/tranny mount kit
BRP 1 7/8 long tube headers
BRP H2 oil pan kit
Custom 2 core Radiator, using a stock 01 camaro duel fan shroud
BIG RJC intercooler
Dakota digital dash cluster
Custom wire harness with E67 ecm and T-42 tcm
Custom LSX duel PCV catch can system w check valve
Lonnies double pumper intank fuel pump
Nasty performance C5 filter/regulator returless fuel system
Alky Control methanol injection system
PTC 10.5" 2,800 TQ converter
motron #60 pound injectors
fuel rail shim kit
i need a 3" duel exhaust system with X pipe made and a 3.5-4" driveshaft
this is all i can remember right now
Ill keep you guys posted as i do the conversion
This as of right now is just a pipe dream but I guess its a good thing for right now so I can read and learn as much before I'd dive into it.
I like how the F-body Accessories are compact.
I have the BRP (Hedman) 1 7/8"/3" Headers, they hang beloy, but I have a ton of ground clearance, and I'm lowered a little bit.
Here is a pic..
[/IMG]
[/IMG]
