The G-Body Swap Thread
Old Mar 13, 2011 | 09:47 PM
  #461
the_merv's Avatar
I'm using the Jegs 700R4 Crossmember, had to modify the location for the T56.
Old Mar 14, 2011 | 12:37 AM
  #462
GNCLONE's Avatar
I got the LQ9 sitting in there, but will have to do some more work with these trans dapt swap mounts.
With all the grief everyone seems to be having, I think I am going to try to fabricate my own crossmember.
Old Mar 14, 2011 | 09:56 AM
  #463
ranloachi's Avatar
I've been making progress on putting an LY6 into my 79 Malibu. I am running it in front of my Coan turbo 400 and will be putting on my ds1 Procharger. Since my motor is mounted, using Moroso solid motor mounts and a Hooker ls stock location mount plate I'm ready to install some headers. I was hopping I could get a little direction of the choices availible. I have heard that the pacesetter 1999-2002 camaro headers fit with a little dent. If this is so a pictures would be good. Thanks for your suggestions and help.
Old Mar 14, 2011 | 05:39 PM
  #464
01cherryreds10's Avatar
The Pacesetters are going to require some beating if you choose the BRP mounts. But I think for the adapter plates for SBC clamshells they should fit pretty nicely.
Iceman Racing has some really nice crossmembers. The TH350 one I had before worked perfectly, and I found out with the mounts I have, his 4L60E crossmember works really nicely too. Shame you have to piece this whole swap together instead of buying a kit. It's hard enough trying to pick out your accessories, cam, heads, intake, trans etc. plus all of the wiring.
Old Mar 14, 2011 | 07:36 PM
  #465
builder1's Avatar
Got the jegs crossmember also had to cut the ends off where they bolt to the frame and modify them to fit my elcamino. The jegs unit is inexpensive and well made
Old Mar 14, 2011 | 07:58 PM
  #466
the_merv's Avatar
That and clears the Exhaust very well.
Old Mar 14, 2011 | 08:33 PM
  #467
BLWN1's Avatar
WHich mounts did you use? Did you mount them already?
Old Mar 14, 2011 | 11:11 PM
  #468
GNCLONE's Avatar
Default Good news!
Good news if you are doing a G body swap and can not/ do not want to go with the high dollar motor mount combos. I got the Trans Dapt LS1 kit for Chevy S10s [PN#4516] for $69 it comes with everything you'll need! Mocked it up this afternoon and bolted in the stands a few minutes ago. I plan on bolting the motor in tomorrow!
Old Mar 14, 2011 | 11:13 PM
  #469
the_merv's Avatar
The front end of the Monte Carlo and S-10 are pretty much the same..
Old Mar 14, 2011 | 11:20 PM
  #470
BLWN1's Avatar
I have the transdapt mounts, but my frame side isnt right, or my clamshells are wrong, Im about to weld them in, but rather not. Im getting some free time to actually work, and the weather is getting warm....
Old Mar 15, 2011 | 08:40 PM
  #471
ranloachi's Avatar
I reused the Moroso solid frame and engine mounts that I had used on my first generation small block and I added the Hooker LS plates that put the motor in the stock location so my tranny would not move. And yes this far has been installed.
Old Mar 16, 2011 | 05:25 PM
  #472
YOUNGDEEZY's Avatar
Is there any cali guys who has done this swap and made it 100% smog legal with the referee inspection? if so can you please post specs and pics on your exhaust setup from headers to the back. i mainly would like to see some true dual x-pipe setups and where the cats are placed etc. its tuff building a performance ride in cali with all this smog bs. i had to let go of my hooker headers because of smog.....thanks in advance i hope a few pics will pop up for me.
Old Mar 16, 2011 | 07:17 PM
  #473
02ls1maro's Avatar
i just put mine in this week and it fit perfectly just a lil close to the drivers side floor pan....t-56
Old Mar 20, 2011 | 07:27 PM
  #474
fastozls2's Avatar
any pics
Old Mar 22, 2011 | 03:51 AM
  #475
toyin's Avatar
24 pages and im sure it's in here but what did you guys do for a harness? Did you build your own? Did you have one made and if so who did you use? Please post up if you would.
Old Mar 22, 2011 | 06:47 AM
  #476
John B's Avatar
Moderator
Speartech all the way baby!
Old Mar 23, 2011 | 06:38 PM
  #477
the_merv's Avatar
I built my own..used a '99-'02 LS1 Harness for the Engine, adapted that to a 1998 Camaro Fuse Box, and integrated that Fuse Box into the Chassis Wiring of the Car. I also went through the stock Dash Harness and eliminated the extra junk.
It all works like stock.
Old Mar 23, 2011 | 06:57 PM
  #478
82lsx cutlass's Avatar
I used transdapt 4575 plates that puts the motor 1inch further back. In the stock location with the stock clamshell mounts it dropped in perfect.
Old Mar 30, 2011 | 01:33 PM
  #479
spacemanspif's Avatar
I have a 5.3 with the truck accessories. First off I'd like to say that the Ford Econoline power steering pulley clears the MCSS steering box in my car with motor mount adapter plates that do not set the engine back. The factory belt seems to be tight enough too so no need to get a slightly shorter belt.
My question is about the power steering lines. Should I use factory MCSS pressure and return, factory truck lines, or some combo of both? I know some people are running truck accessories so this has to be an easy question to answer.
TIA
Old Mar 30, 2011 | 01:49 PM
  #480
speedtigger's Avatar
Old School Heavy
Would anyone be willing to tell me the dimensions for a stock G-body gas tank?
