The G-Body Swap Thread
Old Apr 11, 2011 | 11:27 PM
  #501
G-Body's Avatar
sawzall wielding director
Those appear to be BRP mounts, IIRC they did or do make a kit for the g-body, and those mounts look very similar to their other kits.
With the mount positioned like that and the outlet lines on the compressor you will probably be able to get in in there with a small notch to the k-member, or maybe you won`t even need that depending on how far back those mounts position the engine.
The vintage air systems say that they can`t use the new style variable displacement compressor. However it looks like you have the same clutch cycling compressor setup that I used on my car and it works great with the rest of the GM G-Body system.
Old Apr 12, 2011 | 06:25 PM
  #502
BADLUK's Avatar
so i may get lucky and everything should fit.. does anyone have a picture of an a/c compressor mounted down on the bottom in their swap??? i'm just trying to get a rough idea of what i'm doing here... seeing one already done would be nice.
what can/should i do about those lines running where the compressor will be?
Old Apr 13, 2011 | 12:01 AM
  #503
G-Body's Avatar
Heres some pics of the cut that I had to make. I thought I had some of the compressor with it in there and assembled, but I can`t find them right now. If you have trans lines running through there you would have to make new ones, and re-route them. Mine run higher up on the inner fender.
Attached Thumbnails The G-Body Swap Thread-accut1.jpg   The G-Body Swap Thread-accut2.jpg   The G-Body Swap Thread-accut3.jpg   The G-Body Swap Thread-accut4.jpg   The G-Body Swap Thread-accut5.jpg
The G-Body Swap Thread-accut6.jpg   The G-Body Swap Thread-accut7.jpg   The G-Body Swap Thread-accut8.jpg
Old Apr 13, 2011 | 07:45 AM
  #504
BADLUK's Avatar
thats exactly what i needed! thanks!! i just realized i have to figure out how to wire this thing up now.. ugh. i had already thought about the a/c lines and figured i would have to take to a shop to get those made and hooked up. i've got the clip and about a foot of wiring still on the compressor and its just been cut off, do those wires come from the harness somewhere? i may have to pull the wire loom off and search for the other end of these cut wires, damn.
Old Apr 13, 2011 | 11:38 PM
  #505
G-Body's Avatar
What year and application is your PCM from. Some are easy to wire via the LS1 PCM, other years you have to use the a/c system from your car.
Old Apr 13, 2011 | 11:54 PM
  #506
BADLUK's Avatar
02 chevy truck... let me know where to look so i can get a little more detailed answer for you, i really want to know how to get this all working!
Old Apr 14, 2011 | 05:45 AM
  #507
transamdave's Avatar
Originally Posted by cornfed74
Been waiting to complete the project before I contributed to this thread- which has, and this site, been a wealth of knowledge for pulling off the swap. Here we go. . .
Car: '84 Monte SS
Drivetrain: 5.7L LS1 and 4L60E from '01 TA w/ 52k miles. Bought from Cleveland Pick-a-part
Goal was a close-to OEM installation without cutting the car. I wanted to retain a totally stock interior appearance, too.
Radiator: Stock g-body w/ extra nipple for steam hose. G-body Cutlass top radiator retaining bracket. F-body LS1 fans w/ custom brackets for attaching to factory retaining clips. Buick Grand National A/C condenser- passenger side connection and same brackets as MCSS.
Intake: DIY parts from Silicone intakes.com. Stock MAF.
Engine swap parts: Spohn motor mounts, Kwik A/C bracket, BRP Mid-length headers, RetroLSX oil pan, NAPA G-body temp sending unit machined to fit in rear of passenger cylinder head (Vato Zone sending units deteriorated during machining process, Current performance stand-alone module for engine (chassis uses OEM fuse block). 2.5" 304 stainless exhaust w/ H-pipe and Dynomax VT mufflers. Mufflers at idle and normal RPM have factory F-body sound but roar when you spin up the engine.
Trans swap parts: Shiftworks tailhousing, built-to-spec trans cable (couldn't find adequate OEM part), custom trans cable mounting tab, Iceman x-member (not quite bolt-in application), F-body shifter modified to mount in factory G-body location and use stock MCSS shift handle. No mods were necessary to fit MCSS handle to F-body shifter. Shortened OEM MCSS driveshaft- will eventually replace with new driveshaft.
Electrical: Wait4Me performance flashed the ECM and converted the harness. I intended to do the electrical work myself until a local shop opened, Downriver Motorsports Wiring in Romulus, MI. The rates were exceptionally fair and quality of work far exceeded my expectations and abilities. The ECM is enclosed in a custom housing on the passenger toe-board beneath the carpet. The passenger loses about 2-2.5" of legroom.
I have a 34" inseam and could sit comfortably. Also had car dyno tuned. In hindsight, I paid twice for the harness and ECM flash, but it was a relatively inexpensive lesson to learn.
Fuel delivery: Buick Grand National gas tank/fuel pump/sending unit/, 'vette filter/regulator, currently have -6AN line from tank to engine but have plastic line to replace it when the weather breaks.
Fittment: RetroLSX pan is the cat's ***. Front cross-member is ~5" off the ground and the pan is tucked from harms way. ~1/8" clearance between stock steering box and alternator pulley. Pass rear spark plug is touching A/C box. I plan to clearance the box when the weather breaks. The engine-to-AC clearance is why the harness is draped over the rocker covers. BRP headers would have melted the OEM steering shaft. Jeep XJ steering shaft was too bulky, so I got it right with Borgeson hardware. Clearance is still a scant 1/8-1/4". BRP header flanges negated use of stock trans cable mounting tab.
Lessons learned: I'd not buy a harness or tune twice, and I'd opt for making my own trans x-member or just buying a G-force unit. I bought the Iceman used but never installed and didn't receive paperwork with it to know if I had the correct application or not. Unmodified fitment was like a saddle on a cow, but it worked out fine. I'm very satisfied with the end result. In hindsight I shouldn't have pussed out and cut the car. Had I gone that route it would have a T56.
Other stats: SC&C Stage 2, SPC tubular lowers and springs (all corners), SC&C frame brace, Vari-Shocks on all corners, Currie upper and lower rear arms, Baer Track 13" kit on OEM spindle, Baer Track 12" kit on rear, 18" Rushforth Fuel on Khumo Ventus tires.
Open issues: headliner repair, driveshaft replacement, purchase DIY A/C lines & charge system, wait for snow to melt and enjoy.
This makes me sick. I had a 84 MCSS same color as this one I had high hopes of swapping a LQ4/9 into it along with a saginaw 4spd I bought to put in it. Sweet looking cars guys, keep it up.
Old Apr 14, 2011 | 03:35 PM
  #508
Nanner's Avatar
Will the accessories off an F-Body work in a g body swap? Without A/C, obviously.
Old Apr 14, 2011 | 04:03 PM
  #509
deuce4935's Avatar
Yes, but the alternator may come into contact with the gear box depending on which adapters you use.
Old Apr 14, 2011 | 11:57 PM
  #510
G-Body's Avatar
If it is the red and blue PCM you should be able to wire it up to the PCM. What you really need is someone with HPTuners or EFILive to check the programming and see what operating system is in there, The red and blue PCM`s have multiple ways to hook the A/C up depending on if they used a truck, vette, or f-body operating system when they retuned that computer.
Old Apr 21, 2011 | 07:57 PM
  #511
MonteHawk's Avatar
Default Holley Motor Mount Swap Plates for G bodies
After a year of waiting these are finally for sale. this is what Holley used when they put together "El Camino Verde" with an LS3 and 4L60E. Jegs has the entire line in stock.
Hooker Headers 12621 - Hooker Headers LS Engine Swap Mount Plates, $113.00
These swap plates bolt to the engine and bolt directly to the stock clamshell motor mounts. They move the engine 1 1/4 forward and 1/2 up. Holley also used what I believe is the Youngs F-Body Motorsports AC compressor mounting kit for a 3rd Gen F Body AC compressor on an LS1. I think a serpentine R134 remanufactured compressor from a 90-92 3rd Gen or S10 truck will work well.
Old Apr 21, 2011 | 08:15 PM
  #512
the_merv's Avatar
Man you can find them on Ebay for cheaper..and IMO I would want to keep it in the stock locatin instead of moving it around..that's just me tho.
Old Apr 25, 2011 | 06:28 PM
  #513
ddwilly's Avatar
hey i tried going to your website but no luck. im doing a 5.3 in my 86 monte ,and i need some pointers on some motor mounts.
Old Apr 25, 2011 | 11:04 PM
  #514
01cherryreds10's Avatar
Anyone using the pacesetters have to beat the hell out of one of the primaries to fit right on the passenger side? I've nearly closed one tube in half and it fits, but it hits the frame still. I still have to get a stall converter and trans so a set of BRPs may be out of my budget right now.
Old Apr 26, 2011 | 08:19 PM
  #515
Monte LS....1's Avatar
Ill try to get some pictures of the pacesetters I cut and welded to fit the car tomorrow. I was suppossed to do this a while back for you guys, but changed jobs and got side tracked from the car. Just now getting back around to working on it. Motor is long blocked, need to put the new waterpump, vic jr, and edelbrock 4 barrel tb on. get the headers coated and put everything in the car. Itll be paint and body for the car after the race season is over.
Old Apr 26, 2011 | 08:44 PM
  #516
samckitt's Avatar
I thought the Pacesetter ones were supposed to fit as-is without cutting, hammering, welding?
Old Apr 26, 2011 | 10:32 PM
  #517
With the LS adapter plates with SBC clamshells they supposedly do, however I was stupid enough to buy the BRP kit which raises the engine up an inch or two. Thanks to this kit the swap has been a total nightmare.
Live and learn though
Thanks Monte LS......1, we have similar setups with the headers, mounts, and trans crossmember.
Old Apr 27, 2011 | 11:39 AM
  #518
lamdenali's Avatar
Originally Posted by rickbat
Pictures of John B motor mounts. Worked perfect BTW...
We need John B to get back on he Saddle and start making these mount again
Old Apr 27, 2011 | 06:58 PM
  #519
John B's Avatar
Moderator
Thanks for the props, however, when my job took me out of the Country for two years everybody and their brother started to offer mounts and at prices for less than it cost me to manufacture mine so I just stopped offering them since I won't compromise quality for price.
Old Apr 28, 2011 | 12:30 PM
  #520
lamdenali's Avatar
John If you have time can you make me 1 set cuz I dont know anybody and there BROTHER is making them , I dont mind Paying what you ask for
thx
Lenny
917-613-6054
