The G-Body Swap Thread
Old Apr 28, 2011 | 12:30 PM
  #521
lamdenali's Avatar
Infact John I'll take 2 set cuz am doing 1 malibu and a GN
thx
Lenny
Old Apr 28, 2011 | 02:11 PM
  #522
sbcregal's Avatar
Finally tackling this swap. And I just HAD to register at LS1Tech...:-D
So has anyone been successful with the truck intake? I just sat mine in for the first time, just to get a bit of motivation. It actually did the opposite of that. Looks like an LS1 intake and rails are in my future. My question would be, how much lower does the engine sit with the f-body pan as opposed to the 5.3 truck pan? I know the f-body pan is little bit under 1" shallower at the front of the motor, is this enough to get the intake to clear the hood? And what is the best method for relocation of the alternator?
Old Apr 28, 2011 | 03:34 PM
  #523
lamdenali's Avatar
Who's mount are you using ? Look like the tie rod is gonna hit the pan
Old Apr 28, 2011 | 04:22 PM
  #524
sbcregal's Avatar
It's just hanging on the hoist right now. I'm going to be fabbing my own mounts. I just lowered it down as much as possible to see if it was going to be possible for the alternator and truck intake to clear.
Old Apr 28, 2011 | 09:01 PM
  #525
John B's Avatar
Moderator
thx
Lenny
Let me see what I can do.
Old Apr 28, 2011 | 11:38 PM
  #526
pmgm's Avatar
Has anybody had any luck with the Street & Performance sbc to ls mounts?
Old Apr 29, 2011 | 01:43 AM
  #527
the_merv's Avatar
You mean these?
Old Apr 29, 2011 | 06:52 AM
  #528
5.3 cutty's Avatar
I know I could use a set!!!
Old Apr 29, 2011 | 01:50 PM
  #529
lamdenali's Avatar
There you go John 3 set already sold LOL
Old Apr 29, 2011 | 02:56 PM
  #530
robbyredneck's Avatar
manifold clears but the alternator and the turbo required some fitment work.
Attached Thumbnails The G-Body Swap Thread-regal-001.jpg   The G-Body Swap Thread-regal-002.jpg   The G-Body Swap Thread-regal-003.jpg
Old Apr 29, 2011 | 03:06 PM
  #531
deuce4935's Avatar
Kwikperf.com for the alternator relocation bracket, S&P adapters, H3 oilpan.
Old Apr 29, 2011 | 03:31 PM
  #532
MonteHawk's Avatar
Default Holley engine mounts
Originally Posted by the_merv
Man you can find them on Ebay for cheaper..and IMO I would want to keep it in the stock locatin instead of moving it around..that's just me tho.
Merv, actually they are NOT on Ebay. Yes, you can get plate adapters all over ebay. I posted this up because others may want to use thier stock clamshell mounts with this instead of a BRP mount or changing to an earlier style rubber mount with the plate. Just another option. I can tell you after seeing both the Holley El Camino Verde and the Hot Rod Magazine 79 Z28 which both used this set up on last years Power Tour I was very impresssed with the quality and cleanliness of the swap. It goes together like OEM. Again, another choice, maybe not for you, but I shared it for others like myself that have been waiting for this set up to become available. Best of luck on your Monte, it looks like a lot of fun with that 408. Sounds great.
Old Apr 29, 2011 | 10:21 PM
  #533
sbcregal's Avatar
I'm drooling. Thats was my stock color BTW.
Are you running PS? If so, do you have a pic of your line setup? And what kind of modifications did you have to make to get the alt to clear? And how far above the crossmember is your pan hanging? Mine sits a good bit lower then yours, so I think I'm just going to bite the bullet and get a pan for it. I need to keep telling myself about the "long run"...
Old Apr 29, 2011 | 11:52 PM
  #534
the_merv's Avatar
Thanks..it scoots a little more than that 305..
I was referring to the plates..Ive had good luck with them and for $35 ya can't really beat em..
Old Apr 30, 2011 | 07:25 AM
  #535
stock pump and i used the origional regal lines just unlooped them a little. i die ground the top of the alt. and the pan is a stock truck pan with about 5/8" of an inch clearance .
Old May 2, 2011 | 06:42 PM
  #536
driven87's Avatar
this is my lsswap into 85 regal that is coming close to getting done.
Old May 2, 2011 | 09:03 PM
  #537
the_merv's Avatar
FAWK...
Plug wires look like fun..
Old May 2, 2011 | 09:07 PM
  #538
BAD78BU's Avatar
Default LQ4 swap in 78 Malibu
Originally Posted by G-Body
The LSx/G-Body swap is fairly popular, but yes we can always use more . Did you find the El Camino swap thread? Theres a bunch of pics in my fquick account and a video
So what did you do for the power steering pulley
Old May 2, 2011 | 09:16 PM
  #539
Monte LS....1's Avatar
Originally Posted by samckitt
I thought the Pacesetter ones were supposed to fit as-is without cutting, hammering, welding?
Nope, used some adapter plates and sbc mounts on this car and used brp mounts on the other car i did. I didnt use headers on the first car, but id say it wouldnt work with the brp mounts either. with the sbc mounts, drivers side is basically drop in. fit to close to the cross piece in the frame for me so i modified it slightly but would have worked without modification. Passenger side has to be modified. One of the tubes runs into the lower control arm mount in the frame. I ended up taking the first two primaries and cutting them, swapping them aroung and reworking them for more room. Got a little carried away in one spot, but left it anyways. heres couple pics. bout got blown away with some tornadoes so this is first chance i've had to post....
Old May 2, 2011 | 09:17 PM
  #540
heres couple more pics....
